Slowly the R5 is coming back together ! #1075536
09/15/11 02:30 PM
09/15/11 02:30 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
as most remember i dropped an ex. valve in the R5
broke just under the locks
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075537
09/15/11 02:34 PM
09/15/11 02:34 PM
sycamore,ohio
sycamore,ohio
thanks to Rick from JE Pistons
he did a custom set of domed billets for me
tightened up the bore clearance on it and a little tricker gas porting
should love the added compression
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075538
09/15/11 02:37 PM
09/15/11 02:37 PM
sycamore,ohio
sycamore,ohio
Dennis from AFD is working on the heads
should be done any day now
stepping up to 7mm int and 5/16 ex stems on the valves and getting rid of the mini top lock stuff
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075539
09/15/11 03:17 PM
09/15/11 03:17 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
It's got to be one of the, if not the baddest 1x4bbl 358" engines around.
Re: Slowly the R5 is coming back together ! [Re: HardcoreB] #1075540
09/15/11 04:34 PM
09/15/11 04:34 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Pistons are sweet Bob!! I thought you had Slawko doing your heads?
Re: Slowly the R5 is coming back together ! [Re: STEFF] #1075541
09/15/11 04:48 PM
09/15/11 04:48 PM
sycamore,ohio
sycamore,ohio
Dennis is repairing my Bill Davis heads
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075542
09/15/11 05:29 PM
09/15/11 05:29 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
looks slow.....and small.........
Re: Slowly the R5 is coming back together ! [Re: joshking440] #1075543
09/15/11 05:48 PM
09/15/11 05:48 PM
sycamore,ohio
sycamore,ohio
your time is coming soon !!!!!!!!!!!!!!!!!!
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075544
09/15/11 07:47 PM
09/15/11 07:47 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Bob and Josh,where do i send entry for extreme 10.5 at MMW...
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075545
09/15/11 08:16 PM
09/15/11 08:16 PM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Hi bob,
Where do you get the torque specs for the fasteners on these engines?
the nascar guys dont give out much info on them.
Re: Slowly the R5 is coming back together ! [Re: drago] #1075546
09/15/11 08:23 PM
09/15/11 08:23 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Cant wait to see it done and see how it likes the compression
Drago, I have almost all the torque specs, what do you need?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Slowly the R5 is coming back together ! [Re: DemonDust] #1075547
09/15/11 08:45 PM
09/15/11 08:45 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
Bob,how much compression are you adding and how much more power do you think it will add? Your combination is AWESOME!
Re: Slowly the R5 is coming back together ! [Re: DemonDust] #1075548
09/16/11 12:27 AM
09/16/11 12:27 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
That'd be great - i;ll PM you.
thanks
Re: Slowly the R5 is coming back together ! [Re: drago] #1075549
10/11/11 07:12 PM
10/11/11 07:12 PM
sycamore,ohio
sycamore,ohio
fully radius's and prepped piston ready for wash and assembley
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075550
10/11/11 07:13 PM
10/11/11 07:13 PM
sycamore,ohio
sycamore,ohio
all new guides / seats and camber repaired from Dennis at AFD
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075551
10/11/11 07:14 PM
10/11/11 07:14 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
lolz~
Mopar Performance
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075552
10/11/11 07:15 PM
10/11/11 07:15 PM
sycamore,ohio
sycamore,ohio
all new Titanium coated valves
2.200 / 1.600
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075553
10/11/11 07:16 PM
10/11/11 07:16 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Man he does nice work Bob... Did you ever make any shake down runs before the engine trouble?
Re: Slowly the R5 is coming back together ! [Re: BobsProFab] #1075554
10/11/11 07:17 PM
10/11/11 07:17 PM
sycamore,ohio
sycamore,ohio
should be around 14.5 on compression, need to cc every thing up
Re: Slowly the R5 is coming back together ! [Re: Bob_Coomer] #1075555
10/11/11 07:24 PM
10/11/11 07:24 PM
sycamore,ohio
sycamore,ohio
Bob, one and only shake down pass in Ky shifting at 6,600
leaving off idle an foot braking it went a 5.86 @ 114
convertor flashes 8,200 and make peak power over 9,000 should run a little faster on a all out pass
