Re: What factors do you use to determine oil viscosity?
[Re: 440Jim]
#1075527
09/15/11 05:41 PM
09/15/11 05:41 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I am not the authority on this, but my 2-cents:
- Engine oil temperature - Bearing clearances - Oil system design / volume - Valve train type (e.g. flat tappet vs. roller) - HP expectation (ie bearing load)
....AND rod side clearance
[Re: ahy]
#1075529
09/15/11 10:37 PM
09/15/11 10:37 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Engines that have rod/crank bearings undersized for the expected load (boost on an original n/a motor is a good example of this) will require a heavier weight oil.
I'd consider expected oil temp & bearing clearance the other critical factors.
[Re: BradH]
#1075530
09/16/11 02:28 AM
09/16/11 02:28 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
MY personel N/A drag race pump gas 5W20WT Valvoline non synthetic, same on the street High output(above 800 HP) drag race motor 10W30WT or 15w40 or 25W50WT Pennzsoil racing oil ,depending on the customers desires
[Re: Cab_Burge]
#1075531
09/16/11 03:32 AM
09/16/11 03:32 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
My I dont consider Oil Viscosity when I set bearing clearance, so bearing clearance or any other bottom end spec shouldnt be a factor for selecting Oil. If you have 100 PSI at idle with thick oil, its a screw up anyways, and should be addressed, about 30% more oil pressure than needed. I run thicker oil for added protecting from "break down" I dont run the zero weight oil, and very light oil. Sorry but a 1% increase in performance isnt worth it. I try to run 15W-50. This oil has been around a long time, and is the best I have tried. I will run a Semi Synthetic on occasion. Great stuff here. Run a Accumulator, it will provide more protection than anything else. http://www.schaefferoil.com/. .
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Dap]
#1075535
09/16/11 04:25 PM
09/16/11 04:25 PM
BradH
Dwayne puts my stuff together. So it gets whatever he says to use..
He tells me to run 20w50... but I keep having this occasional delusion that I'm smarter than him.
