E Body - MSD Box, Where to Hide #1075224
09/14/11 09:42 PM
09/14/11 09:42 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Does any one have any good idea's on where to hide a MSD box in a E-body. I thought about the glove box but not sure about the box over heating. I really dont want to see that big box.
Paul
Re: E Body - MSD Box, Where to Hide [Re: faud88] #1075225
09/14/11 10:57 PM
09/14/11 10:57 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
Consider mounting it under the battery tray.
Re: E Body - MSD Box, Where to Hide [Re: TransAm Twins] #1075226
09/14/11 11:43 PM
09/14/11 11:43 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Done this on a few E's. Works pretty good.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E Body - MSD Box, Where to Hide [Re: moparmarks] #1075227
09/15/11 12:26 AM
09/15/11 12:26 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Above the parking brake..
Re: E Body - MSD Box, Where to Hide [Re: TransAm Twins] #1075228
09/15/11 11:53 AM
09/15/11 11:53 AM
OWL
Culvers Offline
Culvers  Offline
OWL
Culvers
Re: E Body - MSD Box, Where to Hide [Re: 1_WILD_RT] #1075229
09/15/11 02:43 PM
09/15/11 02:43 PM
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: E Body - MSD Box, Where to Hide [Re: moparmarks] #1075230
09/15/11 02:50 PM
09/15/11 02:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'f you want to do it that way what I did was unbolt the E brake assy & slide it out so I could insert an "L" shaped bracket, the bracket had two holes that the studs mounting the E brake passed thru & then on the other side of the "L" I drilled two more holes & tacked a couple nuts to the back side... This gives a very solid mount at the firewall end then I replaced the bolt at the front of the E brake assy with a length of all-thread & used a nut to secure the E brake & two more nuts (one front & one back) to support the plate The MSD was mounted to..
Oh & yeah I cleaned the wiring up, that picture was taken early in the mock up phase...
Re: E Body - MSD Box, Where to Hide [Re: 1_WILD_RT] #1075231
09/17/11 07:18 AM
09/17/11 07:18 AM
NH
72challorange Offline
He's Game
He's Game
NH
Here's where mine is. Have since swapped to MSD box. Wasn't too bad to swap when everything was in(engine-rad etc).
Tom
Re: E Body - MSD Box, Where to Hide [Re: 72challorange] #1075232
09/17/11 10:36 AM
09/17/11 10:36 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Another one for under the battery tray. I mounted the box right-side up and on the actual tray, for there was no way I was drilling holes in a virgin inner fender. No moisture being trapped this way either.
Easy access to the RPM chip too.
Re: E Body - MSD Box, Where to Hide [Re: TransAm Twins] #1075233
09/17/11 12:44 PM
09/17/11 12:44 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I would have but didn't want to run wires to the trunk.
I like hiding it behind the glove box liner
Re: E Body - MSD Box, Where to Hide [Re: faud88] #1075234
09/17/11 03:19 PM
09/17/11 03:19 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
It may or may not fit due to size, but see if it will fit behind the headlight on the drivers side. I mounted a Jacobs Ignition box there on my Challenger conv. and nobody ever saw it.
