Duster 15x7 or 15x8 rally wheel offset and tire size? #1075208
09/14/11 08:02 PM
09/14/11 08:02 PM
North Austin
KnuckleDuster Offline OP
North Austin
Ok guys and gals,bear with me here...
I ran a search on this and it always seems to go round and round and get overcomplicated due to b-body rears,moved springs and oddball wheel and tire sizes...
I just need to hear from somebody running 275/??/15 on a 15x7 or 15x8 Stockton or Wheel Vintiques rally wheel Duster/Demon/Dart Sport with stock location springs ONLY
I just need a definitive answer on tire size and backspacing for one rim or the other (15x7 or 15x8)so I can order wheels and tires...
PLEASE
To be crystal clear here is my setup -
ESPO 1" over springs in stock location,factory stock a-body 8-3/4" rear with drum brakes.
PICS WOULD BE AWESOME!!!! THANKS!!!!
Almost on the road ...finally
Re: Duster 15x7 or 15x8 rally wheel offset and tire size? [Re: KnuckleDuster] #1075209
09/14/11 09:43 PM
09/14/11 09:43 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
72 duster here. stock spring location. stock 8.25 out of 75 dart. Stock brakes. 15x8 4.5 backspace Wheel Vintiques ralleys. 275/60s. VERY close to springs. Tires rub on the springs sometimes when making a sharp turn. A thin wheel spacer would probably take care of it ,but when i build an 8.75 for it i may have the housing done just a little wider than factory A body width.
Re: Duster 15x7 or 15x8 rally wheel offset and tire size? [Re: forphorty] #1075210
09/15/11 06:09 AM
09/15/11 06:09 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
A friend ov mine had a 72 Demon with stock (HD) rear suspension on what was pretty much a F.A.S.T car, a few years before that became popular. The ONLY visible clues his car wasn't bone stock were headers ("Dealer installed!" haha) and 15x8" steelies with 265/50/15 tires. Those were Ramcharger rims and have a 4 1/4" backspace. No problems. I've seen those same rims on another Duster before as well... dont remember the tire size... they were 275's and either 50's or 60's, i forget. Again, no issues.
Watch your 'claimed' correct backspaces and sizes, there was a thread on that very thing in here not too far back where the 'factory' backspacing on certain manufacturers was not what it was supposed to be.
Re: Duster 15x7 or 15x8 rally wheel offset and tire size? [Re: KnuckleDuster] #1075211
09/15/11 03:23 PM
09/15/11 03:23 PM
Central New York
bfury Offline
bfury  Offline
Central New York
I have a stock '72 Duster 340 with P275-60/15 with no problem. I had my 14" ralley wheel centers put in a 15 x 8 rim by Specialty Wheel in Oregon. He gave me all the backspace he could by moving the center as far back in the wheel as he could. I believe it is 4-3/8" backspace. I use air shocks to raise the car a 1/2" and they work fine.
No Stock
