Thrust flange ?? #1074909
09/14/11 06:48 AM
09/14/11 06:48 AM
Ohio
fiddlestix Offline OP
Ohio
I have a 74 440 block with the 3.930" diameter thrust flange. I am going to use Indy aluminum main caps and they are cut for the 3.624" thrust flange bearing. Do I need to have the cap cut for the bigger flange diameter or just use the smaller flanged bearing? Is the bigger flange any better than the small? Thanks for any help!!
Re: Thrust flange ?? [Re: fiddlestix] #1074910
09/16/11 06:32 AM
09/16/11 06:32 AM
Ohio
Ohio
Anyone??
Re: Thrust flange ?? [Re: fiddlestix] #1074911
09/16/11 06:50 AM
09/16/11 06:50 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I just used the small one.
