Re: How rare is a 8 3/4" 2.76 sure grip?
[Re: rave_12000]
#1074712
09/16/11 01:17 AM
09/16/11 01:17 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
i pulled an 8 3/4 2.76 sure grip out of a 69 sport satellite back in the day. i am not sure if i am correct, but i always expected that the higher (or taller...hee, hee) geared stock third member would likely produce a less strained or "abused" sure grip carrier...and the carrier might be a better candidate to throw in a rebuilder third member without actually rebuilding the carrier.
Did I hear Bigger ? ... aka TALLER ? ... ...
...so I am NOT alone ...
[Re: Pacnorthcuda]
#1074713
09/16/11 01:34 AM
09/16/11 01:34 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Good God Doc! This is still going on? Give it up--you're wrong on this one.
no kidding , all the protologist of fibberglASS is doing is padding his post count ... you guys are on hook line and sinker ...
[Re: JohnRR]
#1074714
09/16/11 01:38 AM
09/16/11 01:38 AM
dOrk !
Florida STAYcation
Oh Mr Sunshine .... If there is ANYone here that is guilty of padding his post-count ...IT IS you .. And did you finally grow-a-pair enuff to stop blocking me ? ...
[Re: DrCharles]
#1074715
09/16/11 06:39 AM
09/16/11 06:39 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
I've had enough of his "facts". Another one for the blocked list. <plonk> That'll make this thread about 75% "shorter" so I can read through it "faster"
Oh [Edited by Moparts - Family Friendly Site - Keep it clean]... now that is funny.
As for the rest ov you longtallshortlow bastards... I hope you're happy. You've ruined my beautiful thread.
[Re: DoctorDiff]
#1074716
09/16/11 08:54 AM
09/16/11 08:54 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
While I should not feed the troll, DocF, I do not think it means what you say it means.... here's DocDiff's reply: Quote:
2.76 ratio: "high" speed gear
4.88 ratio: "low" speed gear
Transmission: "low gear" first gear
Transmission: "high gear" overdrive
Transfer case: "low range, compound low" low speed
Transfer case: "high range" high speed
where in here does he call a 2.76 a "short gear" and a 4.xx a "tall gear"?
tall/high gears = NUMERICALLY smaller short/low gears = NUMERICALLY bigger
what's confusing you is the proper way to think of it is the inverse of the stated ratio, as the important way to look at it is "X" input creates "Y" output
a 2.76 gear means 2.76 turns of the driveshaft turns the wheel once. a 4.88 gear means 4.88 turns of the driveshaft turns the tire once, so to compare, you need to normalize the input.
with 4.88's 1 turn of the driveshaft turns the tire .205 times
with 2.76's 1 turn of the driveshaft turns the tire .362 times
.362 > .205, and therefore the 2.76 (SMALLER NUMERICALLY) is "taller" or "higher"
in 15 years as a degreed mechanical engineer, you are the ONLY person I've ever heard consider a 2.76:1 gear as a "low" or "short" gear, and a 4.10 as a "high" or "tall" gear.
[Re: Pale_Roader]
#1074717
09/16/11 09:37 AM
09/16/11 09:37 AM
Posts: 21,500 N.E. OHIO, USA
A12
N.E. OHIO, USA
There you go, this b@st@rd did his part to try to restore the "beauty" of this thread which should have been answered in maybe three or four replies IMO but that might be a tall tale.
MikeR
[Re: A12]
#1074718
09/16/11 10:00 AM
09/16/11 10:00 AM
Pale_Roader
Swears too much
Swears too much
There you go, this [Email]b@st@rd[/Email] did his part to try to restore the "beauty" of this thread which should have been answered in maybe three or four replies IMO but that might be a tall tale.
MikeR
Hahahahahaha. Aww... they're pretty...
Oh wait, do you mean a tall tale or a short tale now...??? I'm confused... does DocF get tall when he's angry...???
