Scarebird users what wheels? #1074563
09/13/11 09:06 PM
09/13/11 09:06 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Ive got everything ready to go for the swap. What wheels are you guys using with your scarebird front disc brakes?
Re: Scarebird users what wheels? [Re: Nirvana] #1074564
09/13/11 09:17 PM
09/13/11 09:17 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
I'm running cragars. The first set of calipers I had on it had some ridges that I had to grind down. The second set had no ridges and fit better . The lesson here: not all reman calipers are the same.
Re: Scarebird users what wheels? [Re: pyp1000] #1074565
09/13/11 09:21 PM
09/13/11 09:21 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Your car looks great! How are you liking the scarebird set up?
Re: Scarebird users what wheels? [Re: Nirvana] #1074566
09/14/11 12:17 AM
09/14/11 12:17 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Is anyone running 14x6 slots?
Re: Scarebird users what wheels? [Re: Nirvana] #1074567
09/15/11 10:49 AM
09/15/11 10:49 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
bump
Re: Scarebird users what wheels? [Re: Nirvana] #1074568
09/15/11 11:40 AM
09/15/11 11:40 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
I'm running one of the earlier Scarebird kits with GM truck calipers, early Jeep XJ 15x7's and 1.25 bolt on spacers. Never been happy with any of it... pedal feels like there's nothing there then almost locks up. Need to figure it out, but too many other problems, so it doesn't get driven much. BTW, no 14's would not fit mine.
I also had to make some additional spacers for my Fury rotor and clearance their bracket for the lower ball joint. I would assume they've fixed that by now.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Scarebird users what wheels? [Re: closer9] #1074569
09/16/11 11:42 PM
09/16/11 11:42 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Ya, I have heard a lot of guys are not satisfied with the early kits. Supposedly the new kit can be used with the stock 14x4.5" poverty wheels.I really want to run some 14x6 slots,but dont want to buy the wheels and find out that they dont fit.
87 D100 225 4 speed.
Re: Scarebird users what wheels? [Re: Nirvana] #1074570
09/17/11 01:42 PM
09/17/11 01:42 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
What car are you putting these on, and what parts do they use?
Got some trans woes to work through, then brakes need to be next.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Scarebird users what wheels? [Re: Nirvana] #1074571
09/17/11 10:43 PM
09/17/11 10:43 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
on my dart I used 14 in rally wheels
Re: Scarebird users what wheels? [Re: closer9] #1074572
09/17/11 11:12 PM
09/17/11 11:12 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Going on my 69 Dart Custom with the stock 9in. drums. It uses chevy celebrity calipers,toyota previa rotors,and caddy eldorado hoses. I was skeptical about this combo of parts,but after I bought the calipers/rotors/hoses I no longer have doubts. The calipers are HEAVY and BIG! they seem bigger than the stock single piston units,also the rotors are very nice,and the hub/mounting surface is very thick,so I am not worried about having them drilled for the 5x4" pattern.
Re: Scarebird users what wheels? [Re: Nirvana] #1074573
09/17/11 11:54 PM
09/17/11 11:54 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
my combo is same as yours except i used the chevy celeb rotors, had to drill them tho... did you have to drill yours?
had a hell of a time finding a good m/c.. changing to pwr brakes soon
Re: Scarebird users what wheels? [Re: Dakota_Don] #1074574
09/18/11 12:11 AM
09/18/11 12:11 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Don-
Did you drill your rotors yourself? I havent drilled mine yet,I was thinking about taking them to a machine shop to have them drilled,I dont want to mess em up. But ya you still have to drill the previa rotors,they are slightly shorter than the celebrity rotors so they fit in the stock 14" wheels.Im thinking about using the lighweight mopar master with a 15/16 bore.
Re: Scarebird users what wheels? [Re: Nirvana] #1074575
09/18/11 02:25 AM
09/18/11 02:25 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
yes i did
Re: Scarebird users what wheels? [Re: Dakota_Don] #1074576
09/18/11 02:37 AM
09/18/11 02:37 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Did you just use a hand drill?
Re: Scarebird users what wheels? [Re: Nirvana] #1074577
09/18/11 07:30 AM
09/18/11 07:30 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
A hand drill could be use, but it would be pretty easy to mess up the rotor. A drill press would be better I'd think.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Scarebird users what wheels? [Re: GO_Fish] #1074578
09/18/11 07:06 PM
09/18/11 07:06 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Ya thats kinda what I was thinking.
