hilborn injection #1074502
09/13/11 07:28 PM
09/13/11 07:28 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
how dependable would one be on a mild hemi in a street car? Not a FAST injection setup, but one of the ones with a belt driven fuel pump.
Scott
Re: hilborn injection [Re: maxie] #1074503
09/13/11 07:35 PM
09/13/11 07:35 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I was looking into the Hilborns, but for the wedge...and not mechanical but electronic...thats the way I would go..
Re: hilborn injection [Re: smokinwoody] #1074504
09/13/11 07:39 PM
09/13/11 07:39 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
for electronic hilborn it is about 7500 from what I have seen
Re: hilborn injection [Re: maxie] #1074505
09/13/11 07:45 PM
09/13/11 07:45 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
so very true...but Im thinking it can be done for less...maybe 6k...and thats a lot of beans...
I was also looking at the Inglese systems..unfortunately they dont have the manifolds other than the 392 Hemi...they do sell components..and they can make up sheet metal type intakes...
Re: hilborn injection [Re: maxie] #1074506
09/13/11 07:47 PM
09/13/11 07:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Electronic is really the way to go on the street. There will be those that can and have run MFI on the street, but the learning curve, drivability and MPG all conspire against you.
Re: hilborn injection [Re: RodStRace] #1074507
09/13/11 08:53 PM
09/13/11 08:53 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Piece of cake...
Re: hilborn injection [Re: Mopar_Rich] #1074508
09/13/11 11:29 PM
09/13/11 11:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
And that ain't cheese cake
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: hilborn injection [Re: maxie] #1074509
09/14/11 01:01 AM
09/14/11 01:01 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Are you kidding?
Boffin Emeritus
Re: hilborn injection [Re: maxie] #1074510
09/14/11 12:53 PM
09/14/11 12:53 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
But seriously. I have done quite a few of Hilborns using the FAST XFI. The systems work very well with a few caveats:
* To get a stable vacuum signal (map signal to the ECU) hoses are run to a vacuum accumulator box. This works fine but there is no provision for using an IAC (idle air control). ECUs use both an IAC and timing control to control idle RPM. Without an IAC idle speed is harder to control.
* With 8 butterflys as the engine gets hot, the spacing can change causing an increase in idle RPM. This is a generic characteristic of any system like this. Usually the ECU can compensate.
* The eight stacks must be synchronized to get a good idle.
* If the engine is high in HP, and the car is light, the "tip in" just off idle can be hard to control with your foot. Street cars are no problem, but big injected Hemis in light hot rods can be a hand full.
* Finally, you must run sequential injection using a dual-sync distributor or other method (at least that's all I would ever do). Since there is very little plenum space under each butterfly, bank-to-bank injection causes fuel to sit waiting for the valve to open. The cam overlap can cause a "pop back" through the stack. This happens only at idle. With sequential injection you inject just as the valve starts to open. The mixture goes directly into the chamber and no pop back occurs.
But the throttle response is great and the HP is as good as the normally aspirated engine can get.
My typical FAST XFI 2.0 system with all components, injectors, etc., and the Hilborn manifold runs about $6500.
BTW: You should seriously consider an electric EFI fuel pump. Once running, belt drive pumps work fine but they are usually reserved for high HP engines that require the extra RPM based flow. Starting a street car with a belt driven pump is tough. High HP guys, running belt driven fuel pumps on the street, add an separate electric fuel pump just for starting. But I wouldn't do it on a street car. There are plenty of EFI electric pumps that will handle well over 1000 HP.
