Re: Idle problem
[Re: Aspen7695]
#1074431
09/13/11 04:33 PM
09/13/11 04:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The advance is all in by 1500 rpm. Timing is at 36*. Wires and plugs look good. It does not miss when I make a run. I just got the fuel and as stated above it does not miss during the run.
Raul
You advance would be dropping off as soon as you put it in gear... fatten up the idle screws and see if it holds... still could be the advance... you could make it come in just a little higher RPM
Re: Idle problem
[Re: Aspen7695]
#1074433
09/13/11 08:58 PM
09/13/11 08:58 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
The others are right, you can't have full advance in at 1500 which is the out of gear idle speed and then drop it to 1200 in gear and expect it to idle. My question is though why is it idling at 1500 to begin with? My .700 lift roller cam small block with a tunnel ram will idle at 1100 all day. Unless this is a huge roller in a small cube small block Super Stock application, something is wrong.
There are many tricks to help the TQ idle circuit, I'm no TQ guru but I've modified a few and they worked good. I can tell you that many of those carbs have idle restrictors in them, turning the mixture screws out only goes so far. Also if you open the throttle blades with the idle screw too far (1500! yikes) you are already into the transition circuit and not on the idle circuit. You may need to drill the primary throttle blades and idle restrictors to get the air and fuel flow necessary without the large throttle blade opening.
