SRP vs Diamond vs.....
#1074308
09/13/11 01:07 PM
09/13/11 01:07 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I didn't want to mess up the Wiseco/Diamond thread so thought I'd start my own....
Re: Wedge shelf pistons:
How would you compare the quality of SRP products vs Diamond?
How would you compare SRP products to Wiseco?
I know "just buy them and make up your own mind", but it'd be cool to hear any opinions before laying down the cash.
Is an SRP shelf stock Wedge piston comparable to the two others, in your opinion?
Rich H.
Esse Quam Videri
Re: SRP vs Diamond vs.....
[Re: BradH]
#1074311
09/13/11 01:46 PM
09/13/11 01:46 PM
ZIPPY
S.E. Michigan
Sorry Brad....I was asking or comparisons to the the Pro Tru, since that's all I have used before. Not the super whiz bang models.
This particular question was for 4 & 3/8 bore, 3 and 3/4 stroke flat top big block stuff. But any general quality comments are welcome.
Stroker things will be coming along too, but I've got Wiseco pistons for the 4.500x4.150....and the other one that will need 4.560 or more with an as yet unknown stroke will have to get customs, and will more than likely be Diamond since they're local/easy to deal with and so on. You'll be in the loop like always.
The srp's looked like good nice bang for the buck, and wanted to try them on a couple stock block buildups at some point.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1074312
09/13/11 01:53 PM
09/13/11 01:53 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have the SRP's in mine and they seem to be real nice quality. I would assume they are the same quality as JE since they are made by the same co. I have the flatops in my 499 R/B.
67' charger 499 RB
10.57 at 127
[Re: ZIPPY]
#1074313
09/13/11 02:02 PM
09/13/11 02:02 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I went with SRPs in my SB stroker. I compared prices and specs on just about every piston available for my combination and they were the best bang for the buck.
FWIW, I got my through CNC Performance.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1074314
09/13/11 02:13 PM
09/13/11 02:13 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I was thinking SRP is the econo line of JE Pistons. SRP's are good pistons... Diamond can make some nice pistons. I had a custom set made and they were killer. Now CP pistons are better than any of these mentioned.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: ZIPPY]
#1074315
09/13/11 03:58 PM
09/13/11 03:58 PM
Posts: 2,091 Delray beach, Florida
Performance Only
the SRP's are and okay piston, so are the Pro-Tru's. i don't consider either of them a top quality piston, more like middle of the road quality wise. we use them in mild to medium street/strip combo's. for the more serious stuff we use Diamond Pistons. sometimes the drawback to the typical shelf SRP and Pro-tru comes in the form of valve pocket diameter and depth and also wristpin size availability. with Diamond i can change that stuff for a small fee to better fit the application. the overall quality and strength from Diamond is far superior overall IMO. just so you know, we handle all of the above lines so there is absolutely no bias in my reply.
machine shop owner and engine builder
[Re: Locomotion]
#1074318
09/13/11 08:26 PM
09/13/11 08:26 PM
Guitar Jones
The SRP's are a good quality shelf stock piston. Are they top of the line? No. Will they work for an intended application? Yes, if they fit the bill. I would always prefer to use a shelf stock piston if possible just because of the $ savings, I'm not looking for every last .10 of a horsepower. Unfortunately I can't use a shelf stock piston as the valve reliefs can't be made deep enough without hitting the upper ring land. But if they'll work for you and you aren't talking about an all effort engine I wouldn't hesitate to use them.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1074319
09/14/11 09:15 AM
09/14/11 09:15 AM
ZIPPY
S.E. Michigan
Sounds like they should fit the bill nicely, thanks for the comments guys.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1074320
09/14/11 11:49 AM
09/14/11 11:49 AM
Posts: 1,030 ohio
67mprfan
ohio
i'm using srp in my stock stroke 440 waiting on pushrods to fire it up will let you know how it goes
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
