What would too much timing do to a motor #1074253
09/13/11 01:19 AM
09/13/11 01:19 AM
MN
dustyswinger Offline OP
MN
A couple of weekends ago I accidently timed my engine at 66 degrees timing and made 2 runs. I havent't run the car in a couple of years and I forgot where my timing mark was.It is a small block 416 with 11.25-1 compression cast iron heads and moly rings I am running 110 fuel. I was running exhaust and didn't hear any detonation. It slowed down a second in the et and 12 mph. After re timing at 36 it runs fine and ET is back where it usually has been and have not seen any smoke from tailpipes. My question is would it hurt the rings or piston ring lands?
Re: What would too much timing do to a motor [Re: dustyswinger] #1074254
09/13/11 01:26 AM
09/13/11 01:26 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
detonation kills wrist pins, rod bearings and piston skirts the worst. no way of knowing unless you pull it apart.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What would too much timing do to a motor [Re: bigtimeauto] #1074255
09/13/11 09:08 AM
09/13/11 09:08 AM
gregsdart Offline
gregsdart  Offline
I would at least pull the pan and check all the bearings. If any show signs of detonation, consult your engine builder. Better to check than lose the whole motor.
Re: What would too much timing do to a motor [Re: gregsdart] #1074256
09/13/11 09:23 AM
09/13/11 09:23 AM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
I did the same thing to mine a few years back, poppin and missing at 3/4 track, ran a full second off my time. Corrected the problem and ran the reat of theyear no problems. When we did pull it apart, all was well. every motor and situation is different though.
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: What would too much timing do to a motor [Re: dustyswinger] #1074257
09/13/11 02:31 PM
09/13/11 02:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Measure top-to-bottom clearance of rings in lands.
If they're tight, the lands got squashed.
Boffin Emeritus
Re: What would too much timing do to a motor [Re: polyspheric] #1074258
09/13/11 04:02 PM
09/13/11 04:02 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I ones ran a street 340 a full night on a chassie dyno at 55* of timing. When i turned it down to 36 hp was almost the same but torque was up by ALOT. Didnt hear any pre ingintion.
Re: What would too much timing do to a motor [Re: sshemi] #1074259
09/13/11 04:12 PM
09/13/11 04:12 PM
P
Paul_Fancsali Offline
P
With 110 octane I seriously doubt that engine was hurt. Just plain had no get up at high end could you damage it sure but if its quiet. Check the oil and filter for particles and then decide
Re: What would too much timing do to a motor [Re: Paul_Fancsali] #1074260
09/16/11 07:24 PM
09/16/11 07:24 PM
MN
MN
I took apart the oil filter and it looked spotless so I think I will just run it. I will take it apart this winter, Thanks For the replies. Craig
Re: What would too much timing do to a motor [Re: bigtimeauto] #1074261
09/16/11 09:34 PM
09/16/11 09:34 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I doubt anything is hurt
Go till she blows !
