Neon won't start #1073989
09/12/11 08:56 PM
09/12/11 08:56 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
My 1998 neon has spark and fuel.The compression is good so I would say the timing belt is intact however it will not start..Anyone have an idea what it might be?
Re: Neon won't start [Re: catman56] #1073990
09/12/11 08:59 PM
09/12/11 08:59 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Codes on the key-dance ?
Re: Neon won't start [Re: catman56] #1073991
09/12/11 09:26 PM
09/12/11 09:26 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
I would double check the spark and good fuel psi.....Ive ran a 96 neon with a nickle size hole in a piston for 100's of miles.....It just wouldnt die !!!! I put a used salvage yard piston in it and 75K more miles on it before i sold it. Great little cars.
If you are shure you have good fuel psi and spark, you might want to look at what the ecm is doing.
Re: Neon won't start [Re: johnzgarage] #1073992
09/12/11 09:44 PM
09/12/11 09:44 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
I got 4 codes..p0300 p0301 p0304 and p0140..The 300 codes are cylinder misfires..I am not sure what the 140 code is
Re: Neon won't start [Re: catman56] #1073993
09/12/11 09:45 PM
09/12/11 09:45 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
clean battery cables and lugs then put them back on, neons will turn over and not get full power/ground to pcm, with no codes the stumper nonfire...
MOPAR OR NO CAR
Re: Neon won't start [Re: hemigod426] #1073994
09/12/11 10:08 PM
09/12/11 10:08 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
Thanks everyone for the the input
Re: Neon won't start [Re: catman56] #1073995
09/12/11 10:18 PM
09/12/11 10:18 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
"Downstream O2 Sensor Stays On At Center"
http://www.neons.org/codes/1gen/1gen.html
Re: Neon won't start [Re: In_The_Pink] #1073996
09/13/11 02:20 AM
09/13/11 02:20 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Check wiring going to the crank sensor. They are bad about the wiring getting burnt up over time. Also the cam sensors are usually good for about 100k and then they are done.
