Chassis Black- primer? #1073880
09/12/11 04:07 PM
09/12/11 04:07 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Just had my K-member and Rear end housing vatted and sand blasted. Will be painting with Extreme Chassis black. Should I prime these pieces first? Expoxy primer ok?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Chassis Black- primer? [Re: JMCFAN] #1073881
09/12/11 04:10 PM
09/12/11 04:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have used Extreme chassis black a bunch of times now, and just use it over bare steel.
Once it dries, it is like a rock
(over freshly sandblasted steel as well)
If you check the directions, it is not recommended to be used over primer from memory as it is
Re: Chassis Black- primer? [Re: OzHemi] #1073882
09/12/11 04:17 PM
09/12/11 04:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Here is how mine came out by the way...
Fresh after sandblasting:
Re: Chassis Black- primer? [Re: OzHemi] #1073883
09/12/11 04:19 PM
09/12/11 04:19 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And after drying (oh, and with the upper control arms on too..)
Once it cured for a couple days, it is extremely tough! (and that is the extreme stuff right over the bare blasted metal)
Re: Chassis Black- primer? [Re: OzHemi] #1073884
09/12/11 04:29 PM
09/12/11 04:29 PM
New Mexico
New Mexico
looks nice! I ordered the paint but will not have for a few days. Does it spray straight or do you thin?
No primer it is then. Thanks!
