Re: Broke the ring gear what should I do? [Re: mopartuner] #1073788
09/12/11 09:01 PM
09/12/11 09:01 PM
NC
440Jim Offline
440Jim  Offline
NC
What gear were you in when this happened ?
1st gear......right on the starting line
IMO, 50/50 chance the sprag is damaged. It might not be completely scattered, but if it has started to lay over it is just a few passes at high power before it lets go.
Is the valve body low band (1st) apply? If so, it is even harder to determine if the sprag is damaged without pulling it apart. But either way an inspection is good insurance.
Re: Broke the ring gear what should I do? [Re: Cab_Burge] #1073789
09/12/11 09:11 PM
09/12/11 09:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The bad part about the 489 case is it uses a crush
sleeve and the caps on the carrier are some what weak...
if you change the cap/caps and go to a solid sleeve
they work fine
I forgot about the steel cap (Mark Willaims offers ) needed on the left side, If your going to stress any of the 8 3/4 center sections you should get one also
Why spend the money on a 8 3/4 getting caps, when you could put that money towards a stronger rear end? It already most likely caused tranny damage, think fixing the 8 3/4 is wise?
Different rear end is the best value and it drops out just like a 8 3/4. He's already got 35 spline axles I believe.
Re: Broke the ring gear what should I do? [Re: Challenger 1] #1073790
09/12/11 09:41 PM
09/12/11 09:41 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
If you broke in 1st gear then the sprag is garbage.I build trannys 8 3/4, the caps won't help because what breaks gears is case deflection
Re: Broke the ring gear what should I do? [Re: 440Jim] #1073791
09/12/11 11:08 PM
09/12/11 11:08 PM
ont,canada
mopartuner Offline OP
ont,canada
It coasts in first when you let off the gas in first so I guess it is not a low band apply valve body,it is a cheetah reverse manual
410 pump gas solis flat tappet cam 10.95 so far
Re: Broke the ring gear what should I do? [Re: WheelsUp73] #1073792
09/12/11 11:18 PM
09/12/11 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure didnt hurt my sprag... and its still in there...
but we all get lucky now and then
