Transmission numbers don' make sense! #1073549
09/12/11 12:09 AM
09/12/11 12:09 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I bought an early B-body 833, the numbers on the stamp are pp833 4326 and above it was G266937, I know that the G is the serial number of the car, but the date does not match what I found in searches, anyone have any thing to clarify this? Thanks Tim
Re: Transmission numbers don' make sense! [Re: astjp2] #1073550
09/12/11 12:45 AM
09/12/11 12:45 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
G is the plant code. (St. Louis)
4326 is June 1, 1973.
Is there a 3 in front of the G?
Re: Transmission numbers don' make sense! [Re: Alaskan_TA] #1073551
09/12/11 01:38 AM
09/12/11 01:38 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
No 3 in front of the G, and its a flanged yoke early B body with a 4.35 input bearing flange. That is why I am confused about the date...Tim
Re: Transmission numbers don' make sense! [Re: astjp2] #1073552
09/12/11 01:49 AM
09/12/11 01:49 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Seems to be a mis-stamp...
I have a '69 casting Hemi but with a '66 assembly date. Looks like someone flipped the "9" over and made a "6" out of it.
Your tranny probably should have been stamped 1963... Someone could have easily grabbed a "7" since it follows six..
Re: Transmission numbers don' make sense! [Re: 52savoy] #1073553
09/12/11 02:05 AM
09/12/11 02:05 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Can you get a clear photo of the numbers & post it?
Re: Transmission numbers don' make sense! [Re: astjp2] #1073554
09/12/11 02:10 AM
09/12/11 02:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'67 & earlier pp833s don't have the VIN pad. Sounds like it is pieced together.
Re: Transmission numbers don' make sense! [Re: 6bblgt] #1073555
09/12/11 03:32 AM
09/12/11 03:32 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
He had 2 Identical tranny's, I will try and get a pic tomarrow. Thanks Tim
Re: Transmission numbers don' make sense! [Re: 52savoy] #1073556
09/12/11 10:33 AM
09/12/11 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No it's OBVIOUS that the trans is a hodge podge of parts as the 63 trans case , actually wasn't 64 the first year for the 833 ??? , didn't have the ID pad on the side of the case.
The trans is anything but something that was factory assembled.
edit ... I see Dan beat me to it
Re: Transmission numbers don' make sense! [Re: JohnRR] #1073557
09/12/11 02:30 PM
09/12/11 02:30 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I got some pics, it has 3 grooves in the cluster gear, and brass shift forks. My other tranny has steel shift fork and no grooves. Here is what I have. Oh and there was a 3 infront of the G. My bad. Tim
Re: Transmission numbers don' make sense! [Re: astjp2] #1073558
09/12/11 02:33 PM
09/12/11 02:33 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Pic 2
Re: Transmission numbers don' make sense! [Re: astjp2] #1073559
09/12/11 02:34 PM
09/12/11 02:34 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Cluster gear
Re: Transmission numbers don' make sense! [Re: astjp2] #1073560
09/12/11 05:09 PM
09/12/11 05:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not an original trans , it is a 73 case from a edit ... St. Luois ... built car , someone swapped the mainshaft and tailshaft housing from a an early ball and trunnion driveshaft onto the front half of the trans along with the side cover it would seem because of the brass forks , 71 and later transmissions used the side cover with the interlock levers and iron forks.
Re: Transmission numbers don' make sense! [Re: JohnRR] #1073561
09/12/11 05:35 PM
09/12/11 05:35 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, so I need to figure out what transmission I need to build. I am building a 572 hemi with 9.5-1 compression. I dont have enough money to build a 18 spline and eventually want to do the Passon 5 speed. I have a Dana with 3.55 gears, so do I combine the 2 transmissions and build a close ratio 23 spline or wide ratio? Tim
Re: Transmission numbers don' make sense! [Re: astjp2] #1073562
09/12/11 09:36 PM
09/12/11 09:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
G - St. Louis
Re: Transmission numbers don' make sense! [Re: Alaskan_TA] #1073563
09/12/11 10:00 PM
09/12/11 10:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
G - St. Louis
doooh
