904/999 gove support galling #1073306
09/11/11 07:44 PM
09/11/11 07:44 PM
CT
turbocolt2.4L Offline OP
CT
trying to stop the support from galling to rear drum on my 999 i machined two grooves in it for oil unit has an A&A LBA clean neut vb if that matters.i also have a 90* cooler fitting in rear of trans but dont think thats the problem.
Re: 904/999 gove support galling [Re: turbocolt2.4L] #1073307
09/11/11 07:57 PM
09/11/11 07:57 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This is a common problem on 904s (at least for me).The most common cure is to bore the bushing for a needle bearing and turn the output shaft for the proper clearance.I've also added some additional oil groves.A&A as well as other performance companies offer the parts modified and ready to bolt in.
Re: 904/999 gove support galling [Re: DavidDean] #1073308
09/12/11 03:33 PM
09/12/11 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rollerizing the output shaft won't help galling of the rear band drum to the support; the 727 can have the rear drum rollerized but I don't know of anybody doing it for the 904.
Moly coating the support like SMR offers might help.
Re: 904/999 gove support galling [Re: John_Kunkel] #1073309
09/12/11 04:32 PM
09/12/11 04:32 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
John you know torqueflites beter than I do.All I can say is it has cured the problem for me.I originally did mine and added oil groves and added an oil hole and bored it and installed a needle bearing and had the shaft turned to fit.There is a pic of a simular unit at A&As website
