A-body disc brake help #1073256
09/11/11 06:32 PM
09/11/11 06:32 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
I have a 1972 dart with 440. it still has the 10" drums all the way around. i want disc up front and possibly keep the small bolt pattern. I have the old kelsey hayes setup for it but i think you have to change one of the a-arms and ball joint or something? Does anyone make discs that will bolt right onto the drum spindle without changing anything?
Re: A-body disc brake help [Re: mopower440] #1073257
09/11/11 07:13 PM
09/11/11 07:13 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
No you only change the a arms with 9" drums or the newer 73-76 big bolt disc. Dr.Diff also makes sleeve so you don't need to change the arms with the 73-76 spindles.
Re: A-body disc brake help [Re: mopower440] #1073258
09/11/11 07:23 PM
09/11/11 07:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The KH stuff should bolt right up to the upper arm, no adapters required. Hopefully, the lower BJ is in place on the KH spindle, if so you are good to go.
Re: A-body disc brake help [Re: RobX4406] #1073259
09/11/11 08:27 PM
09/11/11 08:27 PM
middle Tennessee
middle Tennessee
so i dont need to change anything? just unbolt my drum spindles and bolt in the KH setup?
Re: A-body disc brake help [Re: mopower440] #1073260
09/11/11 08:32 PM
09/11/11 08:32 PM
85086
Lil Herman
Lil Herman
85086
Disc brake lower ball joints ar different than the drum. So if the disc ball joints are good you are good to go.
Re: A-body disc brake help [Re: moparpollack] #1073261
09/11/11 08:44 PM
09/11/11 08:44 PM
middle Tennessee
middle Tennessee
but the KH balljoint will fit in my drum a arms?
Re: A-body disc brake help [Re: mopower440] #1073262
09/11/11 09:19 PM
09/11/11 09:19 PM
RobX4406 Offline
RobX4406  Offline
Yes...
The uppers are no different assuming you have 67-72 UCA's on the car. Same part number for the upper ball joint.
The lower BJ is different drum vs. disc, but, will bolt up to the same lower control arm. The Disc and drum LBJ's do not interchange between spindles.
Re: A-body disc brake help [Re: mopower440] #1073263
09/11/11 09:22 PM
09/11/11 09:22 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
The ball joint "stud" that goes into the hole of the lower control arm is no different between a drum brake, or disc brake, lower ball joint.
The difference in ball joints is DRUM brake ball joins attach to the spindle with 1/2 inch diameter bolts.
DISC brake ball joints attach to the spindle with 9/16 inch bolts.
You can drill out drum brake ball joints to 9/16 without any problems.
That's all the factory did anyway, between the two ball joints.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: A-body disc brake help [Re: hemi71x] #1073264
09/12/11 09:21 AM
09/12/11 09:21 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
There is a company that sells a kit where you can run all the stock components, They have it for the 9" & 10" drums, There is some work involved but not much, Its basically a bracket that bolts to the factory spindle assembly, Then you buy like a celebrity rotor & caliper, I can't think of the companies name off hand, but i want to say "thunderbird" or something like that, i'm sure someone would know.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: A-body disc brake help [Re: joedust451] #1073265
09/12/11 10:05 AM
09/12/11 10:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's scarebird and I still think you have to drill the rotor for the 4" BP ?????
Re: A-body disc brake help [Re: JohnRR] #1073266
09/12/11 01:29 PM
09/12/11 01:29 PM
middle Tennessee
middle Tennessee
ok, so no changing a-arms, thats good, next thing, do i have to remove the a-arms from the car in order to press the balljoints out to swap in the disc spindles? if so, i dont know about that mess..
Re: A-body disc brake help [Re: mopower440] #1073267
09/12/11 01:31 PM
09/12/11 01:31 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Ball joints screw in up top...don't use a press on them!
Re: A-body disc brake help [Re: OzHemi] #1073268
09/12/11 01:32 PM
09/12/11 01:32 PM
middle Tennessee
middle Tennessee
cool! but what about the bottom?
Re: A-body disc brake help [Re: mopower440] #1073269
09/12/11 04:03 PM
09/12/11 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The bottom is the taper fit , take off the nut and use a ball joint fork to pop it out ...
Re: A-body disc brake help [Re: JohnRR] #1073270
09/12/11 04:11 PM
09/12/11 04:11 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Thats it thanks, Still should an easy job & relatively cheap too from what i've heard, just drill for the 4" pattern.
Re: A-body disc brake help [Re: mopower440] #1073271
09/12/11 04:26 PM
09/12/11 04:26 PM
middle Tennessee
middle Tennessee
doesnt sound hard then, just leave my uppers in place and change out the lowers that came on the disc spindles then right? dont even have to remove the uppers from my control arms?
Re: A-body disc brake help [Re: mopower440] #1073272
09/12/11 05:04 PM
09/12/11 05:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No you do not have to remove the uppers from the control arms
Re: A-body disc brake help [Re: JohnRR] #1073273
09/12/11 06:21 PM
09/12/11 06:21 PM
middle Tennessee
middle Tennessee
cool, sounds easy enough then, no special tools or anything, now the only thing i need to figure out is how to release the tension from the torsion bars without getting hurt, never messed with torsion bars before..
Re: A-body disc brake help [Re: mopower440] #1073274
09/12/11 06:41 PM
09/12/11 06:41 PM
Knights Ferry, CA
X
XDMN Offline
XDMN  Offline
X
Knights Ferry, CA
Just put the jackstands on the K member or frame, remove the nut on the lower BJ, pull the tie rod off. whack on the BJ with a BFH and the torsion bar will help pop it off when you whack it right. It will only drop down about 4 to 6 inches at most. Then you should be able to turn the drum away from you, undo the upper BJ nut and again with the BFH, give it a few whacks and it'll drop when you get it right.
put a jack under the lower contol arm and jack it until you can get the new spindle on for the disks.
Bill Adams
69 RR convert Petty Blue
68 Dart post
55 DeSoto Fireflite Sportsman
60 New Yorker
62 300H
65 300L
Re: A-body disc brake help [Re: mopower440] #1073275
09/12/11 06:42 PM
09/12/11 06:42 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
releasing tension just means jacking up the front clip and letting them hang. Remove shock to give yourself a little more wiggle room. Jack at front subframe behind front wheel or as far out on K-member as possible, use jack stands at all cost. The disk spindle is different but the 10 drum LBJ is the same, just has smaller bolt holes as stated. Drill out bolt holes and your set. I used a drill press and a very low speed 9/16 drill with lots of cutting oil. It gets the bit cutting tip very hot as that is the only place it contacts the metal and is not easy clamping it down as it is a weird shape, but it does beat spending 50 per side for new disk LBJ's when only the holes are different. Popping the LBJ's out is not that difficult when you have the right tool. Harbor Freight has a ball joint tool that looks like a "chip bag clip" that uses a threaded bolt on a lever to push the ball joint stud out of the spindle. Works like a charm and is only about 7 bucks on sale . Did you get a porportioning valve? The adjustable ones are very nice but a junkyard disk/drum combo valve works about the same and gives you a brake warning light.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
