anybody got BIG header gaskets for b1 heads need FAST!! #1073032
09/11/11 12:21 PM
09/11/11 12:21 PM
ok
mopdragster Offline OP
ok
I am dynoing Tuesday out of state and came to the realization that I only have 1 Header gasket. I run the FAB SHOP dragster headers and they make their own gaskets to fit and they are big over 2 inches square port size. Anybody got 1 Fab Shop gasket or a set of header gaskets that big they could overnite on monday. I looked for superformance on here but couldn't find any info. You can call me direct at 918-671-4559. Thanks for any help
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: mopdragster] #1073033
09/11/11 12:31 PM
09/11/11 12:31 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Dont bother with them , I use the high temp silicone on my turbo car and the seal up just fine.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: go green] #1073034
09/11/11 01:05 PM
09/11/11 01:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use only silicone myself on my B1MC's.
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: Al_Alguire] #1073035
09/11/11 01:46 PM
09/11/11 01:46 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
ditto
i only used gasket on my headers---till i got my B1MC and the guy i got it from showed me "gutter silicone"-clear---been useing it for 2 years now
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: ROSSIO] #1073036
09/11/11 02:24 PM
09/11/11 02:24 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Sillicon on both my B1-TS engines
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: Diablo] #1073037
09/11/11 02:46 PM
09/11/11 02:46 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
silicone here
but the real track is split the flanges between every cylinder.
99% of leaks can be stopped that way because if there's any of the flange that is warped it will become less to sealwill cure the
home of the
Sox and Martin Hemi Duster
Re: anybody got BIG header gaskets for b1 heads need FAST!! [Re: HEMIFRED] #1073038
09/11/11 03:15 PM
09/11/11 03:15 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Silicon used across the pond as well
As Fred said, split flanges help to reduce blow by
For my B1, I had two outer flanges & shared middle port flange, with the slip on collector made installation & removal easier.
My Hemi has flange for each cylinder, a lot more clamping bolts, again with slip joint.
