Re: Spray-on dry graphite piston skirt break-in coating?
[Re: rt66jim]
#1072961
09/12/11 12:08 PM
09/12/11 12:08 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Graphite "lubricant" in a spray can is definately not something to be used in an engine in my opinion. That would be about the equivelant of pouring fine sand in an engine. Nothing at all like a coating. Graphite lubricant has a lot of fine paricles in it,which is most likely why oil would turn black after break in. Keith
[Re: rt66jim]
#1072964
09/12/11 03:08 PM
09/12/11 03:08 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I sent this question in years ago to Mopar Action, and it was printed in the tech! If you can dig that up. it had a whole article on rattle can piston coatings. Reason I asked back then, he had done a cheap build up years before, and I was asking about the manufacturer of that aerosol coating. I will see if I can dig that mag out. Later Bob
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: BradH]
#1072965
09/13/11 02:35 AM
09/13/11 02:35 AM
Posts: 4,238 State of retirement
52savoy
State of retirement
If you consider that several piston companies supply their pistons coated what does that say? Next time you see a fueler or pro/stock motor tore down look closely at the pistons.. they're coated. I've been coating my own pistons for over 10 years with zero problems but it's not out of a spray bomb. http://www.techlinecoatings.com/hi-performance/index.htmlAs far as graphite.. years ago that's what was used to break-in camshafts. I still use graphite grease and haven't suffered any failures.. Someone once said.."different strokes for diff..folks"
[Re: DoubleD]
#1072966
09/14/11 04:11 PM
09/14/11 04:11 PM
BradH
Considering that dry graphite is corrosive to aluminum parts...
Yeah, I did a bit of Google-ing after noticing your comment and found lots of links about graphite corroding aluminum.
Thanks for the "heads up" on that potential SNAFU.
