Mopar ministarter Q #1072675
09/10/11 03:06 PM
09/10/11 03:06 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Hi,
seems like my ministarter quit. When I turn the key it only clicks. Changed the magnetic switch (don't know the proper name) already from a spare starter, no effect, it moves the gear forward but it doesnt turn.
What can i do?
I think I have eliminated all other possibilities like starter relay, weak battery, corroded terminals.
Is it possible to disassemble the ministarter? Is there anything I should be aware of when taking it apart?
Re: Mopar ministarter Q [Re: 440sat72] #1072676
09/10/11 03:39 PM
09/10/11 03:39 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
the prices are so low its cheaper just to r/r the old one ,i got one used from a recycling yard(?) and it works fine on my 500strkr.
Re: Mopar ministarter Q [Re: moparsquid] #1072677
09/10/11 05:27 PM
09/10/11 05:27 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Not on this side of the pond ... :-(
I thought about mating the two damaged ones into one that works ... bad idea?
Re: Mopar ministarter Q [Re: 440sat72] #1072678
09/10/11 06:26 PM
09/10/11 06:26 PM
Central NC
gch Offline
gch  Offline
Central NC
You have nothing to lose by trying.Go to the local parts store and order one for a 3.9l minivan or truck application.Stock starter is same size and will work fine.I believe you have to remove a tab that older cars don't use.
