starter relay wiring question #1072554
09/10/11 11:22 AM
09/10/11 11:22 AM
AZ - The "dry heat" state
71autoxr Offline OP
71autoxr  Offline OP
for a 1969 Dodge Dart the wiring diagram shows the "G" terminal of the starter relay going to the neutral safety switch. Where does this wire go for a manual transmission? Later years used a clutch safety switch so the wire goes there in 1970+ (i think). I know the wire is grounded, but specifically where did it connect to?
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: starter relay wiring question [Re: 71autoxr] #1072555
09/10/11 12:00 PM
09/10/11 12:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
clutch pedal switch, no other place.
I know some earliers assembly never got a safety switch anywhere ( dunno what year was the last ) and in fact this relays got a tab welded to relay housing to get a chassis ground, but if you have the prong, will go to the clutch pedal switch
Re: starter relay wiring question [Re: 71autoxr] #1072556
09/10/11 12:21 PM
09/10/11 12:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1969 and earlier relays for manual trans car were soldered to the side of the relay case
As in S101 and S78 in this picture
Re: starter relay wiring question [Re: gtx6970] #1072557
09/10/11 01:06 PM
09/10/11 01:06 PM
71autoxr Offline OP
71autoxr  Offline OP
I have never seen that before. Thanks for the info. I love moparts.
