Mopar Leaf Springs... Heavy Duty vs Super Stock #1072497
09/10/11 08:46 AM
09/10/11 08:46 AM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
I am looking at getting some new leaf springs for my challenger. I was looking at the Mopar Heavy Duty (Same as the stock 6/7 leafs on Heave Duty Cars) or the Super Stocks which i do not know much about. Does anyone have any input on these parts and/or pics of the difference from stock to them?
Thanks,
Steve
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: HemiChallenger] #1072498
09/10/11 09:09 AM
09/10/11 09:09 AM
IN
ahy Offline
ahy  Offline
IN
The "Extra Heavy Duty" springs are stock length with a 22" front spring segment. They are a bias design with one side stiffer to compensate for torque reaction but don't make the car noticably "tilted" at rest. As originally designed they put the rear somewhat low. The reproductions have a reputation of sagging after a fairly short time and tend to put it really low. I'm running a set on a Challenger set up for handling and want it a little low. The XHD's are still a little too low for me and I'm going to get them re-worked by the local spring shop to stiffen them and add 1/2-3/4" height.
The "Super Stock" springs are designed for drag racing and have a shorter 20" front segment. They require an extended front hanger to compensate for the short length. They are quite stiff and heavily biased to the point the car may look like its leaning at rest. Some folks buy two right hand springs to gain the stiffness without the tilt for road use.
You can see pics and get more description on Mancini's web site.
There are lots of choices and several vendors. It depends on what you want to do with the car. If you want standard length springs that aren't too low, I'd call ESPO or Firm Feel.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: ahy] #1072499
09/10/11 09:22 AM
09/10/11 09:22 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
ss springs will be quite stiff for a street car,but are good and will not sag
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: mcmopars] #1072500
09/10/11 09:29 AM
09/10/11 09:29 AM
My 65 dart came as a roller w SS 003's on both sides & not up & running yet but they look stout w a healthy bow which required shock extensions. I got a feeling I'll have 2 swap em out
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: RapidRobert] #1072501
09/10/11 08:25 PM
09/10/11 08:25 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
If you go with SS springs I would recomend the 3400 pound springs, the spring rate is a little less IE not so stiff.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: HemiChallenger] #1072502
09/10/11 08:38 PM
09/10/11 08:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Buy em from Spring's and Things(ESPO). I think that's what there called. Either standard height or 1 or 2" over. They don't sag and have held up good for me on 2 challengers.I would not trust much from MP anymore and not springs for sure.
If you want a drag car that sits funny go with the super stock springs from MP with longer front hangers.
Welcome back...
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: Challenger 1] #1072503
09/11/11 03:51 AM
09/11/11 03:51 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe call Eaton Detroit Spring and see what they have. I was happy with the stock reproduction springs I got from them.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: bobby66] #1072504
09/11/11 11:17 AM
09/11/11 11:17 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Any car I've ever had with SS springs rode like an empty dump truck on the street.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: 69L78Nova] #1072505
09/11/11 11:20 AM
09/11/11 11:20 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yup, you're have guys come on here and tell us how great SS springs are for the street, they suck for the street.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: Challenger 1] #1072506
09/11/11 06:03 PM
09/11/11 06:03 PM
Millersville, PA
Millersville, PA
Thanks for the input guys, I'll have to check out these other places, seems like i keep hearing the same feedback on the MP springs being junk after time.
Steve
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: HemiChallenger] #1072507
09/11/11 06:14 PM
09/11/11 06:14 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Thanks,
Steve
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: DPelletier] #1072508
09/11/11 06:17 PM
09/11/11 06:17 PM
DPelletier Offline
DPelletier  Offline
needless to say; the SS springs reside in my "paid a bunch of money for stuff that is never going to get used" pile!
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: Challenger 1] #1072509
09/11/11 06:35 PM
09/11/11 06:35 PM
Aurora, CO
Manifold Offline
Manifold  Offline
Aurora, CO
X3. Have them on my B-body and they are ridiculous on the street. One thing not mentioned is that the current MP SS springs will put the shackle at a bad angle (leaning from front to back versus the correct back to front). I got rid of the shackles and added spring sliders, moved the front eye bolt to the top eye on the extended mount, which got the rear end down to a "normal" looking height.
Still rides rough as hell.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: HemiChallenger] #1072510
09/11/11 06:35 PM
09/11/11 06:35 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I have XHD's on my '74 Challenger. They are ok. No real complaints.
I had the 3800 lb automatic superstocks grafted onto my Volare for about 30 years. They did their job at the track, and I was surprised how well the car still handled. They never sagged. It was a little work to get the car to sit level from left to right. I had the complete police suspension on the Volare for a couple years and that handled really well. So I would know the difference.
I don't know why everyone bashes superstocks. There is more to suspensions and ride quality than springs alone.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: racealittle] #1072511
09/11/11 06:40 PM
09/11/11 06:40 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
ESPO, ESPO, did I mention ESPO? Get their 6 leaf stock height or +1 if you want a little more. Good quality and no sag.
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: Manifold] #1072512
09/11/11 06:43 PM
09/11/11 06:43 PM
2 clarify 4 me should the BOTTOM of the rear vertical shackle b to the rear?
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: RapidRobert] #1072513
09/11/11 06:52 PM
09/11/11 06:52 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
didn't we do this before? yes, pointing towards the bumper. \
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: mikemee1331] #1072514
09/11/11 06:59 PM
09/11/11 06:59 PM
Yes I did
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: RapidRobert] #1072515
09/11/11 07:43 PM
09/11/11 07:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
3400 lb SS springs on my 63 I bought from Mancini. And it dont ride like a dump truck. It rides great and hooks good at the track for the rest of the suspension being stock. I would bet it rides as good as any Mopar on HD leaf springs. It dont bounce all over it just rides normal. Ron
Re: Mopar Leaf Springs... Heavy Duty vs Super Stock [Re: 383man] #1072516
09/11/11 07:53 PM
09/11/11 07:53 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have SS springs on my Cuda and they ride just fine.
