Challenger seat cover install with new foam?
#107248
08/19/08 11:47 AM
08/19/08 11:47 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I noticed the new foam does not have the metal rods in them like the original foam. Whats the correct way to faster the inner section of the covers, to the springs? Thanks for any help!
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Challenger seat cover install with new foam?
[Re: Silver70]
#107249
08/20/08 12:04 AM
08/20/08 12:04 AM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
I just got done completely dissassembling my March 1970 original seats, blasting and repainting the frames, and installing new Legendary covers and foam. The rods you refer to are not in the foam. They are routed through hanging pockets in the original seat cover, then hog-ringed down through the foam onto the bottom frame. You need to re-use your original metal rods when you re-cover.
Until total honesty is on the table, we're not even talking about reality...
[Re: Silver70]
#107251
08/20/08 11:52 AM
08/20/08 11:52 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
I've still got all my old pieces in the garage... I'll check them tonight and let you know... must be pre-senility because I don't seem to recall any metal pieces in my foam...
[Re: RP's R/T's]
#107253
08/20/08 10:55 PM
08/20/08 10:55 PM
Iceman01
Challenged
Challenged
Anchorage, Alaska
If he was talking about the rods that are wrapped in brown paper, you are indeed correct that they are hog ringed directly to the bottom seat frame first, then the rods in the cover are squashed down through the pre-built creases in the foam and hog-ringed to these brown paper wrapped metal rods. I took a lot of photos of mine as I deconstructed them. I'll try to post them later when I get home. You can use them for reference either to build new ones (if yours are missing) or to tie yours down.
FYI -- the brown paper wrapped rods are still available. My custom upholstery guy had plenty of them in straight 6-ft. lengths. He then bends them to the desired shape.
[Re: Iceman01]
#107254
08/21/08 01:33 AM
08/21/08 01:33 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Here's a photo showing where the bottom seat frame rods are positioned. Photo is from my untouched, original seats (LA-built, late Feb 70). I had just removed them, but you can clearly see their shape from the imprint they left on top of the burlap.
Sequentially, the burlap (with thin wires woven through in a loose mesh pattern) go directly on top of the seat frame, followed by the brown paper covered rods on top of that. These are then hog-ringed down through the burlap directly to the frame. Then the felt padding is hog-ringed onto the outer top edges. Then the foam goes over the top of that, followed by the seat cover (with metal rods inserted into the built-in pockets). These seat cover metal rods are pushed down deeply and hog ringed directly to those brown paper covered metal rods that are already tied to the frame bottom. Only then is the seat cover in the correct position to begin folding over the side flaps and hog ringing to the outer bottom seat frame.
[Re: Silver70]
#107257
08/22/08 10:16 PM
08/22/08 10:16 PM
Iceman01
Challenged
Challenged
Anchorage, Alaska
If you're using them in an Challenger and have bought correct E-body seat covers and foam, then I would build them exactly like the E-body originals in my post above. Since we're talking about internal construction, can't see why that wouldn't work, as well as be more correct. My
[Re: Silver70]
#107259
08/27/08 12:26 PM
08/27/08 12:26 PM
Iceman01
Challenged
Challenged
Anchorage, Alaska
I think at this point I'd be shopping for a correct set of 1970 e-body seats.
I know a guy with quite a Mopar seat collection that may be able to hook you up. PM me for details, if interested.
[Re: Iceman01]
#107260
09/05/08 02:57 PM
09/05/08 02:57 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
I need to recover my front buckets also. Anyone recover incorporating a 5 point harness somehow. I don't like the plastic buckets or aluminum look for seats. I want to leave the stock seats for my racecar.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
