Re: 340 engine numbers location
[Re: gtxmark]
#1072281
09/10/11 12:48 AM
09/10/11 12:48 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
"Mopar Engine Casting Numbers 1970. The block casting numbers for all RB, B, and LA engines are found on the left (driver) side of the block. In addition, on 1968 and later engines the numbers stamped on the lower rail of the engines right (passenger) side match the last 8 digits of the cars vehicle identification number. Casting Number CID Year Type Remarks 2780930 340 1968-73 LA Except T/A & AAR
Mopar Head Casting Numbers 1970. The casting numbers for most RB, B, LA heads are found in two places. On the underside of the head on an intake runner, and under the valve cover on an intake runner. Casting Number Engine CID Year Intake Exhaust 2531894 340 1968-70 2.02 1.6
Mopar Intake Manifold Casting Numbers 1970. Casting Number Engine-bbl Year 3462848 340-4 1970
Mopar Exhaust Manifold Casting Numbers 1970 Engine Year Remarks Casting Number 340 1969-70 Barracuda / Right 2863549 340 1969-70 Barracuda / Left 3418623 340 1970 Challenger / Right 2863549 340 1970 Challenger / Left 3418623 340 1969-70 Dart / Right 2863549 340 1969-70 Dart / Left 3614368"
