340 engine numbers location #1072275
09/09/11 06:40 PM
09/09/11 06:40 PM
Ohio
gtxmark Offline OP
gtxmark  Offline OP
Ohio
IS the numbers for sm. blocks stamped somewhere on top of the engine like big blocks i'm going to look at a '70 340 from a cuda but i have only owned big blocks.thanks
Re: 340 engine numbers location [Re: gtxmark] #1072276
09/09/11 06:42 PM
09/09/11 06:42 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
There's a pad on the front of the engine, driver's side, right below the head. And numbers are cast into the side of the block as well.
Re: 340 engine numbers location [Re: gtxmark] #1072277
09/09/11 06:45 PM
09/09/11 06:45 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Front of block drivers side, just below deck.
something like
FM340Pxxxx xxxx
VIN or SO number
68 along bellhousing rail, top side
69+ Pass side pan rail just below drain plug
Re: 340 engine numbers location [Re: dustergirl340] #1072278
09/09/11 06:48 PM
09/09/11 06:48 PM
Ohio
gtxmark Offline OP
gtxmark  Offline OP
Ohio
ok so what numbers represent a '70 340 cuda engine. The engine is currently in a pickup truck so i'm real glad the nos. are on top. Thanks ,I'm not very knowledgeable on sm. blocks
Re: 340 engine numbers location [Re: gtxmark] #1072279
09/09/11 06:54 PM
09/09/11 06:54 PM
RobX4406 Offline
RobX4406  Offline
what I posted should be on the front of a 70 engine.
The first digit "F" is the 1970 model year
D = 1968
E - 1969
F - 1970
G - 1971
H - 1972
J - 1973
Re: 340 engine numbers location [Re: RobX4406] #1072280
09/09/11 07:02 PM
09/09/11 07:02 PM
Ohio
gtxmark Offline OP
gtxmark  Offline OP
Ohio
Thanks Rob,thats what i need to know
Re: 340 engine numbers location [Re: gtxmark] #1072281
09/10/11 12:48 AM
09/10/11 12:48 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
"Mopar Engine Casting Numbers 1970.
The block casting numbers for all RB, B, and LA engines are found on the left (driver) side of the block. In addition, on 1968 and later engines the numbers stamped on the lower rail of the engines right (passenger) side match the last 8 digits of the cars vehicle identification number.
Casting Number CID Year Type Remarks
2780930 340 1968-73 LA Except T/A & AAR
Mopar Head Casting Numbers 1970.
The casting numbers for most RB, B, LA heads are found in two places. On the underside of the head on an intake runner, and under the valve cover on an intake runner.
Casting Number Engine CID Year Intake Exhaust
2531894 340 1968-70 2.02 1.6
Mopar Intake Manifold Casting Numbers 1970.
Casting Number Engine-bbl Year
3462848 340-4 1970
Mopar Exhaust Manifold Casting Numbers 1970
Engine Year Remarks Casting Number
340 1969-70 Barracuda / Right 2863549
340 1969-70 Barracuda / Left 3418623
340 1970 Challenger / Right 2863549
340 1970 Challenger / Left 3418623
340 1969-70 Dart / Right 2863549
340 1969-70 Dart / Left 3614368"
Re: 340 engine numbers location [Re: kentj340] #1072282
09/10/11 01:08 AM
09/10/11 01:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a photo with one 1971 engine decoded as an example
Re: 340 engine numbers location [Re: ScottSmith_Harms] #1072283
09/10/11 01:10 AM
09/10/11 01:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Drivers front of block just below the head
Re: 340 engine numbers location [Re: ScottSmith_Harms] #1072284
09/10/11 01:11 AM
09/10/11 01:11 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The VIN sequence number is stamped here, just above the oil pan rail, passenger side, near the water jacket drain plug.
Re: 340 engine numbers location [Re: gtxmark] #1072285
09/10/11 04:45 AM
09/10/11 04:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The top numbers you find will only tell you what engine, what engine plant & when the engine was assembled.
The partial VIN# off the side will tell you what plant the original car was built at.
If it is a '70 partial VIN# (0Bxxxxxx) Alaskan_TA, Barry, should be able to tell you if it was a 'Cuda, Challenger, or Duster.
