#4 cam journal grooving? #1071849
09/09/11 06:23 AM
09/09/11 06:23 AM
Ohio
fiddlestix Offline OP
Ohio
I am considering grooving my cam for full time oiling. Can anyone tell me what size radius and how deep the groove is?
Thanks for any help you can give me.
Re: #4 cam journal grooving? [Re: fiddlestix] #1071850
09/09/11 01:12 PM
09/09/11 01:12 PM
It's a lot easier to groove the cam, make the groove as wide as the holes in your cam bearing and around .030 deep I do it to all my Hi Po cam motors, you may need to add a oil restrictor in the heads or block Depending on what type and brand rockers and oil pan capacity
Re: #4 cam journal grooving? [Re: Cab_Burge] #1071851
09/09/11 01:27 PM
09/09/11 01:27 PM
Ohio
Ohio
Thanks Cab! I will be using a 7qt oil pan and Harland Sharps. Any other information you need or advice you can give me? By the way it is a small solid roller cam.
Re: #4 cam journal grooving? [Re: Cab_Burge] #1071852
09/09/11 03:06 PM
09/09/11 03:06 PM
Delray beach, Florida
P
Performance Only Offline
P
the typical groove dimensions i use are .025 deep and no more than .050 wide. it should be done with a radiused tool, not a square tool with sharp 90 degree edges.
i would never make the groove as wide as the hole in the cam bearing since they are typically 1/4" (.250") wide. that's way too wide IMO
i would also wonder why you think you need to groove the cam, unless it's a Hemi, which should already be grooved.
machine shop owner and engine builder
Re: #4 cam journal grooving? [Re: Performance Only] #1071853
09/09/11 06:27 PM
09/09/11 06:27 PM
Dan, I have the cam grooved becuase it is easier than removing or having the cam bearing grooved The reason I suggest making the cam groove as wide as the hole in the cam is as you know no two shops make the cam bearing center exactly in the center of the cam boss in the block, so making the groove in the cam as wide as the hole in the camshaft allows oil pressure to the rockers if the cam bearing is not installed exactly in the center of the boss. Even if it is centered exactly doesn't mean the cam will have the oil hole in the cam center in the groove To the OP, make sure and limit the oil feed to your rockers, I would, and do, use a carb. jet around .040 to .080, your call on the size. More oil helps cool the valve springs, that(the bigger volume) is not really needed on a hydraulic or flat tappet cam so I would use the smaller size jets on them IHTHs, Dan, Have a Great Day
Re: #4 cam journal grooving? [Re: Cab_Burge] #1071854
09/09/11 07:13 PM
09/09/11 07:13 PM
P
P
Cab, if the oil hole in the main is in the center of the journal, the oil hole in the cam journal will be in the center. either way, you do it your way and i'll do it my way.
by the way, take a look at any Hemi cam and check the width and depth of the groove in the cam.
Re: #4 cam journal grooving? [Re: Performance Only] #1071855
09/09/11 07:23 PM
09/09/11 07:23 PM
Ohio
Ohio
My reason for doing this was to help keep the valve springs cool. This will be a mostly street driven engine. Thanks for the opinions guys.
Re: #4 cam journal grooving? [Re: fiddlestix] #1071856
09/09/11 07:50 PM
09/09/11 07:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you having a spring problem... the factory didnt
and I think you WRONG to take the oil away from the
mains and rods.... IF I did anything I might put a
spray bar in the valve cover JUST for the springs
Re: #4 cam journal grooving? [Re: MR_P_BODY] #1071857
09/09/11 08:59 PM
09/09/11 08:59 PM
Ohio
Ohio
I haven't even started this engine yet. I was told it might be a wise thing to do for a street driven solid roller cam. This is a small Comp 262@.050" duration .575" lift cam.
Re: #4 cam journal grooving? [Re: fiddlestix] #1071858
09/09/11 09:12 PM
09/09/11 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I haven't even started this engine yet. I was told it might be a wise thing to do for a street driven solid roller cam. This is a small Comp [Email]262@.050"[/Email] duration .575" lift cam.
I'll be running a solid roller 260/270 .620/.620 with
just PR oiling on the street... might be a little
light on pressure at 240# on seat at 2" but its
only a 7000 rpm 416 SB engine
