Solid Cams who runs them? #1071775
09/09/11 02:26 AM
09/09/11 02:26 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Wondering how many of you guys are running flat tappet cams nowadays? I am planning on changing the comp hyd in my 528 hemi and thinking of using a solid. Have buddys telling me that it is old tech and with the oils available today will possibly have problems. So what is your thought on running a solid cam?
Re: Solid Cams who runs them? [Re: SCATPK] #1071776
09/09/11 03:15 AM
09/09/11 03:15 AM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
MP557. Love my sewing machine, and I do run the lash tighter than what MP reccommends. Been in the car 4+ years now. Broke it in with GM EOS and 15/40 dino oil...no issues and I will be goin with another solid cam when its time to freshen/rebuild...
Re: Solid Cams who runs them? [Re: SCATPK] #1071777
09/09/11 05:59 AM
09/09/11 05:59 AM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
I am running a solid flat, and my next motor will also. You need to break in the cam with just the outer valve springs then install the inner springs. There are plenty of high zinc oils out there to use, Brad Penn, VR1, Royal Purple, Amsoil. As far as old school tech, these are old school motors! They like old school tech!
Re: Solid Cams who runs them? [Re: 440CIVIC] #1071778
09/09/11 07:15 AM
09/09/11 07:15 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
solid flat here---I love mine-- its nasty. Check out Hughes Engines ---mopar only cams. Great customer service.
i use Brad Penn oil and Hughes additive.
Re: Solid Cams who runs them? [Re: 493_DART] #1071779
09/09/11 09:46 AM
09/09/11 09:46 AM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
Solid here also running a hand me down that was replace with a roller and I think at times he wonders why he botherd he really dident gain a thing and Ive went 10.35 130mph in 3200 lbs car with only 11-1 compression.Useing brad penn oil and this cam is about 10 years old.
Re: Solid Cams who runs them? [Re: SCATPK] #1071780
09/09/11 10:22 AM
09/09/11 10:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had the 528 soild in the 1st 440-6 I ran in this car. ran good. This motor sports a 588 solid roller...I works GREAT. Drives nice, pulls hard and revs like crazy.
Coming soon!!!!
Re: Solid Cams who runs them? [Re: SCATPK] #1071781
09/09/11 10:28 AM
09/09/11 10:28 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I run a solid flat with roller rockers. I use Rotella T 10w30 and a bottle of STP for lube. I couldn't justify the extra cost of a roller.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Solid Cams who runs them? [Re: bigsbigelow] #1071782
09/09/11 11:12 AM
09/09/11 11:12 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I ran a NF-62 Ultradyne solid (270 adv./243 @ .050, .548" for years in a street/strip 9;1 440. Checking lash was a waste of time since it never needed adjusting and with .016" lash it was quiet(not that I care). Cam is still in use in my brothers car and has to have 100000 miles on it by now I got a .620" Ultradyne solid that is going in an SR headed 470 one of these years.
Re: Solid Cams who runs them? [Re: 446acuda] #1071783
09/09/11 11:48 AM
09/09/11 11:48 AM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
Comp cams MM lobes. 440 edelbrock heads 10.7 @ 126 mph on pump fuel at 3700 lbs.
Re: Solid Cams who runs them? [Re: 572B1] #1071784
09/09/11 11:53 AM
09/09/11 11:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a solid flat tappet cam custom ground by Dwayne Porter. It was nitrided and I broke it in about 3 months ago. I used Valveoline racing oil and the comp oil additive with the zinc in it. Broke in fine and has been zero problems. Ron
Re: Solid Cams who runs them? [Re: 383man] #1071785
09/09/11 01:44 PM
09/09/11 01:44 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
During my previous build of the 73 Duster, I elected to go with a solid, flat tappet cam in the SB.. Within a month, I wiped one lobe and had to tear the motor apart.. Since then, I've gone to the solid roller and have had no problems.. (knock on wood)
Re: Solid Cams who runs them? [Re: Jeepmon] #1071786
09/09/11 03:01 PM
09/09/11 03:01 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Don, it would be you with a story of despair and destruction! I have had good luck in the past with solid cams and thinking about stepping the power up on the gtx a bit. Look for me in Sac this weekend as I think I may take a run or two down the track and see if I remember how to drive the thing.
Re: Solid Cams who runs them? [Re: SCATPK] #1071787
09/09/11 03:36 PM
09/09/11 03:36 PM
Guitar Jones Offline
I've had a Hughes flat tappet solid in my small block for about 15 years. I've never had anything but Mobil1 10w30 in it, no additive ever. I did like 440civic said and broke it in with just the outer springs and then added the inners. It's 140 on the seat and 440 over the nose, .672 lift with 1.6 rockers. That's more pressure by about 110 over the nose on the cam than Hughes recommended but it would valve float past 7500, I wanted to twist this thing to 8000 so I added more valve spring. It's been in 2 different blocks with the same lifters and I still haven't had a problem. I've since gotten a roller of near identical specs for my new short block, why I'm not sure after all the hassle this has been, but this cam will still see duty when my kid puts it back together for his car.
Re: Solid Cams who runs them? [Re: Guitar Jones] #1071788
09/09/11 04:27 PM
09/09/11 04:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Forgot to add I broke in my cam on just the outer springs also. Then I used this tool to install the inner springs on the car. This tool worked great and made it easy installing the inners on the car. Ron
Re: Solid Cams who runs them? [Re: 383man] #1071789
09/09/11 05:46 PM
09/09/11 05:46 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went Crane solid roller, with the 66550-16 lifters. With the lack of ZDDP in the oil, I have already gone through 3 jeep flat tappet cams, and the diesel oil is starting to get rid of it also. The next best thing is Phillips 25w60 XC aviation oil, uses other additives for flat tappet cams. Tim
Re: Solid Cams who runs them? [Re: astjp2] #1071790
09/09/11 05:51 PM
09/09/11 05:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Comp .588 solid in my 440.Been in at least 10 years.I adjust and check the lash about every 2 years.Just run Valvoline synthetic race oil.No additives ever.I run Kendall GT1 sometimes also.Rocky
Chrysler Firepower
Re: Solid Cams who runs them? [Re: therocks] #1071791
09/09/11 07:36 PM
09/09/11 07:36 PM
organ
maximum entropy Offline
organ
i like flat tappets. solid or hydraulic. i've run some pretty big ones, all on the street and the strip. let's see, i've had... uh... mmm. it's been 35 years? ida know how many engines. a lot. one lobe on a .508 in a small block back in the early eighties was just starting to go away. caught it by accident doing other work. that was after a couple hundred runs and 45,000 miles. me and flat tappets get along real good.
Re: Solid Cams who runs them? [Re: therocks] #1071792
09/09/11 07:39 PM
09/09/11 07:39 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I run solids in both of my cars, just broke in my Hughes cam with other spring only with there additive and Mobil diesel oil.
Runs great
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Solid Cams who runs them? [Re: 65signet] #1071793
09/09/11 09:01 PM
09/09/11 09:01 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I run a solid in my 416 and my 360 Always pulled the inner springs for break in
PITA but it is what it is
Re: Solid Cams who runs them? [Re: 383man] #1071794
09/09/11 10:27 PM
09/09/11 10:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What brand of spring remover is that? Does it work on #7 valves?
