340 to 416 stroker #1071766
09/09/11 01:41 AM
09/09/11 01:41 AM
oak park, il.
dsd70bee Offline OP
dsd70bee  Offline OP
oak park, il.
Does abyone know what kind of horse power you would get from a 416 stroker kit in a 340 with some head work to a set of "X" heads and a mild hydralic cam and a set of TTI headers?
Re: 340 to 416 stroker [Re: dsd70bee] #1071767
09/09/11 02:18 AM
09/09/11 02:18 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It will all boil down to the entire combo.
Figure a mild to moderate 915 casting port job, dual plane intake, a 750ish carb, and a hyd. street grind cam, probably around 400-425HP 470-490lbs torque.
WAY more porting, a single plane, Holley 950, stout solid or roller cam, more like 475-525HP 475-510TQ.
WAG numbers but should give you an idea of what you'll be getting, The big crank makes a small block car drive like a big block car!
Re: 340 to 416 stroker [Re: dsd70bee] #1071768
09/09/11 02:20 AM
09/09/11 02:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Somewhere around 1hp/cu on the conservative side. Maybe more depending on cam.
Brian at IMM got close to 475-480hp and 490-500 lb-ft but with a fairly worked set of edlebrock heads and lunati voodoo 60403 cam:
https://board.moparts.org/ubbthreads/show...part=2&vc=1
