flex plate #1071521
09/08/11 06:39 PM
09/08/11 06:39 PM
Myrtle Beach
Boot Offline OP
Boot  Offline OP
Myrtle Beach
Bottom end is in the machine shop. 74 360. Machinist is balancing the crank and installing piston and rod assembly. He told me that B&M makes a flex plate to put a neutral balance stall converter on this motor. Anyone know the part #? I see 3 different ones on the B&M website.
Thanks in advance
Re: flex plate [Re: Boot] #1071522
09/08/11 08:32 PM
09/08/11 08:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you are using your stock torque converter that match book size weight on the front of it is the added balance for the 360---if the weight is knocked off it is then zero balanced---be sure to leave the little postage stamp sized weight alone--that is what is used in initial zero balance----in a big block the big weight means it is going to a cast crank----no big weight and it is a forged crank-zero balance--cant see a reason to buy an expensive flexplate---for the same money your local torque converter rebuilder can set you up with a rebuilt zero balance unit---bob
Re: flex plate [Re: Boot] #1071523
09/08/11 08:36 PM
09/08/11 08:36 PM
10239
Re: flex plate [Re: RapidRobert] #1071524
09/08/11 11:45 PM
09/08/11 11:45 PM
Myrtle Beach
Boot Offline OP
Boot  Offline OP
Myrtle Beach
thanks
Re: flex plate [Re: RapidRobert] #1071525
09/09/11 04:55 PM
09/09/11 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That number is for the 904 only (OP didn't specify which trans), 10236 is correct for the 727.
