Clutch 10.5 and 11 Inch What Flywheel? #1071020
09/07/11 05:35 PM
09/07/11 05:35 PM
fury4speed Offline OP
Can a 11" Clutch be bolted on a 130 tooth flywheel? or does an 11" clutch use a 143 toth flywheel? thanks , and what clutch does a 172 tooth flywheel take? what flywheel uses a 10.5 inch clutch? thanks.
All for a Hemi 8 Bolt Crankshaft in a 426 Wedge Engine.
Re: Clutch 10.5 and 11 Inch What Flywheel? [Re: fury4speed] #1071021
09/07/11 07:36 PM
09/07/11 07:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The true 11" pressure plate is used on 143 and 172 tooth flywheels but the factory used the 10.95" scalloped pressure plate on the 130 tooth flywheel from '70-on (much factory literature refers to this as an 11")
Re: Clutch 10.5 and 11 Inch What Flywheel? [Re: John_Kunkel] #1071022
09/08/11 09:56 AM
09/08/11 09:56 AM
Thanks for the info.
