451 short block ??? #1070948
09/07/11 03:19 PM
09/07/11 03:19 PM
nc
E
earthmover Offline OP
E
nc
got a chance at a 451 short block at a good price...want to ask a few ??? on this before i try to pull the trigger...short block has 14.1 comp pistons with 72 cc heads (my heads are 72cc as well) it has a 690 roller,mil gear drive, with billet mains,and studs,good crank and rods..now what kinda power could i see with this motor ..my heads should go 350 with the bigger valves and gasket matched (2.25 val)
-1 with t&d 1.6 rocker,intake i guess i will look for the 400-2 as i have a 440-2 for a 440block with the 2" spacer,buddy has a nice 1150 carb...
all this will be fit to a 727 trans no brake as of now,either 8" 5600 verta or 9.5 5000 verta, in a 70 duster about 2900lbs right now...suspension will be up graded to backhalf ladder bar with coil over and a dana rear..
will this combo get me down in the low 6's in the 1/8 mile without much trouble?????just getting a feel of this before i go ahead and buy the short block thanks mike
Re: 451 short block ??? [Re: earthmover] #1070949
09/07/11 03:30 PM
09/07/11 03:30 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It will run well. It will want to RPM though. Shift points will be 7200+, to make it run half way decent...
Get the a loose converter, and leave the line at 6K will help. Those -1's can be a hair lazy down low in moderate heavy car 3000 lbs+ and usually soft in 60ft times.
I ran a similar combo with CNC ported -1's from Modern, jesel rockers bla bla bla. In a moderately heavy 3400 lbs Dakota... It would 60ft lazy in the mid 1.30's range but run out the strip with killer MPH 114+ (im taking stock stroke here)
The compression will help if its really 14:1.... Even with those tight 72cc chambers the pistons are probably blob domes near 20 CC..
Its just very difficult to get a 3.75 stroke engine to 14:1.. thats all.
Re: 451 short block ??? [Re: earthmover] #1070950
09/07/11 03:32 PM
09/07/11 03:32 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
In short..yeah, no problem. You'll have to spin it to 7,500 or so to optimise the ET. Use the 8" converter.
Re: 451 short block ??? [Re: Bob_Coomer] #1070951
09/07/11 03:43 PM
09/07/11 03:43 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good point. It would probably run better milling more from the heads and lopping off the domes(the pistons intake pocket will most likely need radial clearence anyway w/ a 2.25 int), provided you have enough P-2-V depth. Honestly, I would consider a custom ground cam for about $200 more.(factor-in selling the current cam)
Re: 451 short block ??? [Re: HardcoreB] #1070952
09/07/11 03:54 PM
09/07/11 03:54 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Just a thought
If it is stock block, you may be making more than a stock block will like for very long, especially at 7500 rpms and 14:1. It looks like you have enough head flow and cam to go 700+.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: 451 short block ??? [Re: clovis] #1070953
09/07/11 04:41 PM
09/07/11 04:41 PM
nc
E
E
nc
so the -1 will make the shift points out of this world?????maybe i can get this and get my set up going and run some 6.50 and not set it on kill all the time ...give me a idea of what would be the best way to run this ....im sure there are a bunch of 400/451 guys doing pretty good with this set up...this way i can save some coin for a good block down the road..thanks mike :
Re: 451 short block ??? [Re: earthmover] #1070954
09/07/11 05:17 PM
09/07/11 05:17 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
No problem there we used to run 6.10 1/8 and 9.79 1/4 in a 2900 lb charger with same combo. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: 451 short block ??? [Re: earthmover] #1070955
09/07/11 05:22 PM
09/07/11 05:22 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Keep the camshaft to a moderate size. It would be easy to over cam this one, and not being able to make it up in the upper revs, it will not see.
Id shoot for a cam that would make the good cylinder pressure.
Id look for a cam in the mid 250's to low 260 for dur@50 with as much lift as you can get.
Id use a 6K minimal converter, and 4.56' to 4.88's gears depending on tire height.
I switched over to a toilet setup mid year and that thing really made the power down low. I really like that alky injection system. Easy to tune etc.
Re: 451 short block ??? [Re: Bob_Coomer] #1070956
09/07/11 06:01 PM
09/07/11 06:01 PM
nc
E
E
nc
good to hear that it can and does work well ...im just trying to get this thing going and be able to upgrade later ,just didnt want to burn cash i dont really have right now..mike
Re: 451 short block ??? [Re: earthmover] #1070957
09/07/11 07:26 PM
09/07/11 07:26 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Not sure how much of my combo relates to yours,,but thought i would post mine,
(Porter Racing did the motor)
451, tall fill, .055 over
ross dome pistons
BME rods
Ohio Crank 4340 stock stroke
Flat tappet cam 304/304, 272/272, 108 lsa, 650 lift w/1.6 rockers
13:1 compression
Victor intake,
Dominator 1050
edelbrock heads
made 650 HP @7200 and 564 tq at 5800
this is in a 3450 lb Belvedere.
Best ET so far,,(foot braking),,,was a 10.08 @ 131MPH
Re: 451 short block ??? [Re: 69CHARGERMD] #1070958
09/07/11 07:56 PM
09/07/11 07:56 PM
nc
E
E
nc
nice
Re: 451 short block ??? [Re: earthmover] #1070959
09/07/11 08:48 PM
09/07/11 08:48 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
nice
Sound like you want what I had. but yours will be better( easier).
I had 3225 lbs, Ported stage IV 2.14/1.81 lucky if they flowed over 285 or so. . 13.75 -1 tarantula manifold, 4780 carb..( 800 cfm
Lunati roller, 276/284 108 .690 w 1.5s. I used 1.6 harland sharps. 9" J type convertor,( 5200 stall. shifted at 7000 hit the stripe at 7500.
5.38s and 14x32s on 12" rim.
What is your cam?
Re: 451 short block ??? [Re: bumps440] #1070960
09/07/11 09:40 PM
09/07/11 09:40 PM
nc
E
E
nc
i got a luntia roll thats 731 lift with 1.6 rockers but i think it has a 690 roller in it now not sure of the specs..mike
but if i could use this to get me through while i get funds for a block ill be ok ..
Re: 451 short block ??? [Re: earthmover] #1070961
09/07/11 11:25 PM
09/07/11 11:25 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Doug
Did you get a bob weight for your engine from Dwayne?
'75 Plymouth Duster
Re: 451 short block ??? [Re: clovis] #1070962
09/08/11 04:21 AM
09/08/11 04:21 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Hi Dwayne, I don't recall a bob weight, I can re look at my papers and see if he mentions it. doug.
