Inverted flare question #1070767
09/07/11 10:51 AM
09/07/11 10:51 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
I found some fuel inlet fittings on eBAY that use inverted flare fittings, but the angles of the inverted flares are 37 degress (AN flare angle). If I flare my fuel line using a 37 degree flare tool, can I use a regular (male) flare nut on the fuel line? Not sure because all of the male flare nuts that I'm aware of are on SAE flared (45 degree flare angle) tubing.
Here's a link to the fuel fittings I'm talking about: http://cgi.ebay.com/ebaymotors/_W0QQcmdZ...RKQ3aMEWAXQ3aIT
ThankS!
Re: Inverted flare question [Re: mrob] #1070768
09/07/11 11:03 AM
09/07/11 11:03 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
i believe you should just be able to use a regular 3/8 flare nut.
71 scamp big block with 915 heads 727 trans
