Question on 68-69 Dart fender-mounted turn signals #1070295
09/06/11 01:16 PM
09/06/11 01:16 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I scored a decent pair of these turn signals this weekend, but the housings need to be rechromed. The only problem is that I can't figure out how (or if) these things come apart. Does anyone make repop lenses? If so, I won't worry about trying to save them.
I can also see no way the socket/wire comes out. Anyone familiar with taking these apart? I wonder if they would just mask the wire/socket and rechrome the unit without disassembling them.
Re: Question on 68-69 Dart fender-mounted turn signals [Re: Mike H] #1070296
09/06/11 01:24 PM
09/06/11 01:24 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Turn the signal over and there is a small set screw that needs to be loosened so you can take it apart. Yes they make repo lenses $65 set if I recall correctly....
Re: Question on 68-69 Dart fender-mounted turn signals [Re: QuickBpBp] #1070297
09/06/11 01:35 PM
09/06/11 01:35 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
For the lenses: http://krusinmoons.com/
Re: Question on 68-69 Dart fender-mounted turn signals [Re: Pntastar69] #1070298
09/06/11 07:33 PM
09/06/11 07:33 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
Thanks for that link! I need them for a 68 Dart,I'm wondering which ones I need....the ones with a slot on the lense, or smooth type?
Re: Question on 68-69 Dart fender-mounted turn signals [Re: 2DoorPost] #1070299
09/06/11 09:32 PM
09/06/11 09:32 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Slot.
JB Rhinehart, Realist
A-Body's RULE!
Re: Question on 68-69 Dart fender-mounted turn signals [Re: Rhinodart] #1070300
09/06/11 10:22 PM
09/06/11 10:22 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
I'll take that to the bank, Thank you!
