67 B-body idler arm image/removal #1070259
09/06/11 11:28 AM
09/06/11 11:28 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang.
I have a friend with a '67 Coronet R/T. He's having some trouble removing his idler arm. Now, I know '68-'70 B's like the back of my hand. But, I 'assumed' '67 B-bodies were similar in that the idler arm is positioned between two mounting ears welded to the k-member and held in place by a long bolt.. Is't the '67's like this as well?
Can anyone post a picture?
Troy
Houston Mopar Connection Club
Re: 67 B-body idler arm image/remmoval [Re: hemi68charger] #1070260
09/06/11 11:32 AM
09/06/11 11:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
pretty sure 67's ( and earlier) have a stud on both ends
Re: 67 B-body idler arm image/remmoval [Re: gtx6970] #1070261
09/06/11 11:43 AM
09/06/11 11:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes they do
Re: 67 B-body idler arm image/remmoval [Re: gtx6970] #1070262
09/06/11 11:44 AM
09/06/11 11:44 AM
Houston, Tx
Houston, Tx
Ahhhhhhhhhhh. Thanks Bill.....
Now it makes sense.. Looks like he'll need a pickle fork for both ends.....
Anyone with a picture from under the car with it installed?
Troy
