firewall mounted master/clutch cyl.? #1070257
09/06/11 11:06 AM
09/06/11 11:06 AM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i am in the process of mounting the master/clutch cyl. on the fire wall of my 47 desoto. the fire wall is angled back about 12*. can i mount the master/clutch cyl. at and angle or do they have to be level? i`m using the pedals from an 88 ram 50, the master cyl. from a late 70`s truck(non power brakes) and a wilwood 3/4" clutch cyl.
Re: firewall mounted master/clutch cyl.? [Re: 65rbdodge] #1070258
09/06/11 01:03 PM
09/06/11 01:03 PM
AZ
Mike P Offline
Mike P  Offline
AZ
I've seen several factory setups (mostly GMs and Harleys) over the years where the MC that were run at a slight angle so it really shouldn't be a problem as long inlet holes are contiounsly covered with fluid.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
