neutral safety switch wiring harness #1070229
09/06/11 10:31 AM
09/06/11 10:31 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
what/where is the neutral safety switch wiring harness attached along its trip from the firewall to the trans? assume it clips/clamps at least at one point along its way.
Car in question is 69 B-body big block 727
Re: neutral safety switch wiring harness [Re: BTTG] #1070230
09/06/11 11:16 AM
09/06/11 11:16 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Kevin..good question! I need the same info! I'm not sure YET,where it plugs into the block on the firewall. Could someone post a pic of their car,with location noted?....and where it gets attached to anything along the way? Thanks!
Re: neutral safety switch wiring harness [Re: BTTG] #1070231
09/06/11 11:20 AM
09/06/11 11:20 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
There is a rubber coated clamp under one of the trans to block bolts, looking at the engine from the rear I think it's the top right side bolt (maybe top left one though)
there should also be another clip on the tail shaft ext to trans case bolt.
I can snap a picture later today of where it connects on the firewall - I have a 69 Charger in the shop
Re: neutral safety switch wiring harness [Re: gtx6970] #1070232
09/06/11 12:53 PM
09/06/11 12:53 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: neutral safety switch wiring harness [Re: BTTG] #1070233
09/06/11 01:08 PM
09/06/11 01:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
On my 71 e body it is the lower left connector on my fuse block looking at it from the engine compartment. It also has the windshield wiper motor wires in it also. 4 wire plug.
Re: neutral safety switch wiring harness [Re: Challenger 1] #1070234
09/06/11 01:36 PM
09/06/11 01:36 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Thanks for the info Bill....and Gary!
Re: neutral safety switch wiring harness [Re: Challenger 1] #1070235
09/06/11 01:59 PM
09/06/11 01:59 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hello Gary,
Could you post a pic of the harness running along the firewall to the fuse block? Also, could you post a pic showing where the harness from the dash reverse light routes under the dash and where it connects to? TIA
Ray
Re: neutral safety switch wiring harness [Re: rayztoy] #1070236
09/08/11 06:17 PM
09/08/11 06:17 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: neutral safety switch wiring harness [Re: rayztoy] #1070237
09/08/11 06:31 PM
09/08/11 06:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sorry I don't have the pictures your asking for.
Re: neutral safety switch wiring harness [Re: Challenger 1] #1070238
09/08/11 07:23 PM
09/08/11 07:23 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Thanks Gary... Anyone?
Re: neutral safety switch wiring harness [Re: rayztoy] #1070239
09/08/11 07:51 PM
09/08/11 07:51 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I have this detail on file and thought it would help.
After the harness comes off the trans, it goes through one black plastic circular shaped wire strap on the firewall.(this is on a 73...I think earlier years used a either a black or white "D" shaped strap) From there it runs accross the firewall and connects to the lower lefthand corner of the bulkhead connector. It only goes through the one strap on the firewall...the one below the voltage regulator. If you want me to take a pic let me know.
Re: neutral safety switch wiring harness [Re: burdar] #1070240
09/08/11 07:58 PM
09/08/11 07:58 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hey Darren,
Thanks for posting! I have that part covered. Just need to know where the harness runs along the firewall to the fuse block, and as the harness leaves the dash reverse light, where does it route under the dash and plugs into where?
Ray
Re: neutral safety switch wiring harness [Re: rayztoy] #1070241
09/08/11 08:00 PM
09/08/11 08:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just edited my previous post with more info. Is that all you need?
Re: neutral safety switch wiring harness [Re: burdar] #1070242
09/08/11 08:42 PM
09/08/11 08:42 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Darren,
Thanks for that info. I believe my 70 cuda should be the same. A pic would be helpful. I need the routing from the dash light under the dash to where it connects to...
Ray
Re: neutral safety switch wiring harness [Re: rayztoy] #1070243
09/08/11 11:22 PM
09/08/11 11:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Mines an automatic so I don't have a reverse light. On mine, only three of the four connector slotts are used. The lower left slot is empty. There is a brown wire with a yellow tracer that comes out of the plug...up and around the brake booster and over to the relay.
Re: neutral safety switch wiring harness [Re: rayztoy] #1070244
09/09/11 07:53 AM
09/09/11 07:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Darren,
Ray
It goes to the wiring bulkhead , should be pretty easy to figure out where it goes , the wire is only so long , taped in a few spots to hold it to the harness . The harness from the trans when it gets to the firewall is held by the same clips that hold the engine harness .
Re: neutral safety switch wiring harness [Re: JohnRR] #1070245
09/09/11 11:23 AM
09/09/11 11:23 AM
Cincinnati, Ohio
Cincinnati, Ohio
Darren,
Ray
Yup easy to figure how it routes, it can only go one way.
Re: neutral safety switch wiring harness [Re: Challenger 1] #1070246
09/09/11 12:03 PM
09/09/11 12:03 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Gents,
Thanks for the previous posts. The harness from the reverse light switch appears to be short as it will mount on the drivers side top bellhousing bolt, not the passenger side top bellhousing bolt, and directly runs to the fuse box via metal tabs on the fiewall. It will not reach the engine compartment harness plastic loops. The harness on the reverse light is just hanging there, and I'm not sure where it connects to. Does it go to the fuse block in the interior side, or does it connect to the main dash harness, or go through the firewall to connect to the engine harness? Any help is appreciated. The reverse lights don't work, so I'm trying to fix them. TIA
Ray
Re: neutral safety switch wiring harness [Re: rayztoy] #1070247
09/12/11 10:38 AM
09/12/11 10:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gents,
Thanks for the previous posts. The harness from the reverse light switch appears to be short as it will mount on the drivers side top bellhousing bolt, not the passenger side top bellhousing bolt, and directly runs to the fuse box. It will not reach the engine compartment harness plastic loops. The harness on the reverse light is just hanging there, and I'm not sure where it connects to. Does it go to the fuse block in the interior side, or does it connect to the main dash harness, or go through the firewall to connect to the engine harness? Any help is appreciated. The reverse lights don't work, so I'm trying to fix them. TIA
Ray
Since your car is a 73 I can't say what was done then , I can only comment on 1969-70 A/B body which went to the bulkhead directly and the reverse light harness was held to the firewall by the rubber tipped metal clips welded to the firewall not the plastic loop clips on the inner fender panels.
Do you have the service manual for your car ? there is a wealth of information in it , like wiring diagrams ...
Re: neutral safety switch wiring harness [Re: JohnRR] #1070248
09/12/11 12:29 PM
09/12/11 12:29 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
His car is a 1970.
