Re: neutral safety switch wiring harness
[Re: Challenger 1]
#1070235
09/06/11 01:59 PM
09/06/11 01:59 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
On my 71 e body it is the lower left connector on my fuse block looking at it from the engine compartment. It also has the windshield wiper motor wires in it also. 4 wire plug.
Hello Gary, Could you post a pic of the harness running along the firewall to the fuse block? Also, could you post a pic showing where the harness from the dash reverse light routes under the dash and where it connects to? TIA
Ray ![](/ubbthreads/images/graemlins/smile.gif)
[Re: rayztoy]
#1070239
09/08/11 07:51 PM
09/08/11 07:51 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I have this detail on file and thought it would help.
After the harness comes off the trans, it goes through one black plastic circular shaped wire strap on the firewall.(this is on a 73...I think earlier years used a either a black or white "D" shaped strap) From there it runs accross the firewall and connects to the lower lefthand corner of the bulkhead connector. It only goes through the one strap on the firewall...the one below the voltage regulator. If you want me to take a pic let me know.
[Re: burdar]
#1070242
09/08/11 08:42 PM
09/08/11 08:42 PM
rayztoy
Richmond, VA
Darren, Thanks for that info. ![](/ubbthreads/images/graemlins/bow.gif) I believe my 70 cuda should be the same. A pic would be helpful. I need the routing from the dash light under the dash to where it connects to... Ray
[Re: rayztoy]
#1070244
09/09/11 07:53 AM
09/09/11 07:53 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Darren, Thanks for that info. I believe my 70 cuda should be the same. A pic would be helpful. I need the routing from the dash light under the dash to where it connects to...
Ray
It goes to the wiring bulkhead , should be pretty easy to figure out where it goes , the wire is only so long , taped in a few spots to hold it to the harness . The harness from the trans when it gets to the firewall is held by the same clips that hold the engine harness .
[Re: JohnRR]
#1070245
09/09/11 11:23 AM
09/09/11 11:23 AM
Challenger 1
Cincinnati, Ohio
Ray
Yup easy to figure how it routes, it can only go one way.
[Re: Challenger 1]
#1070246
09/09/11 12:03 PM
09/09/11 12:03 PM
rayztoy
Richmond, VA
Gents, Thanks for the previous posts. The harness from the reverse light switch appears to be short as it will mount on the drivers side top bellhousing bolt, not the passenger side top bellhousing bolt, and directly runs to the fuse box via metal tabs on the fiewall. It will not reach the engine compartment harness plastic loops. The harness on the reverse light is just hanging there, and I'm not sure where it connects to. Does it go to the fuse block in the interior side, or does it connect to the main dash harness, or go through the firewall to connect to the engine harness? Any help is appreciated. The reverse lights don't work, so I'm trying to fix them. TIA
Ray
[Re: rayztoy]
#1070247
09/12/11 10:38 AM
09/12/11 10:38 AM
JohnRR
Gents, Thanks for the previous posts. The harness from the reverse light switch appears to be short as it will mount on the drivers side top bellhousing bolt, not the passenger side top bellhousing bolt, and directly runs to the fuse box. It will not reach the engine compartment harness plastic loops. The harness on the reverse light is just hanging there, and I'm not sure where it connects to. Does it go to the fuse block in the interior side, or does it connect to the main dash harness, or go through the firewall to connect to the engine harness? Any help is appreciated. The reverse lights don't work, so I'm trying to fix them. TIA
Ray
Since your car is a 73 I can't say what was done then , I can only comment on 1969-70 A/B body which went to the bulkhead directly and the reverse light harness was held to the firewall by the rubber tipped metal clips welded to the firewall not the plastic loop clips on the inner fender panels.
Do you have the service manual for your car ? there is a wealth of information in it , like wiring diagrams ...
[Re: JohnRR]
#1070248
09/12/11 12:29 PM
09/12/11 12:29 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
