UPDATE 9-9-11 Need help trying to prime the oil system. #1069821
09/05/11 06:19 PM
09/05/11 06:19 PM
KC KS or Punta Gorda FL FL
VOABIRD Offline OP
VOABIRD  Offline OP
I posted yesterday that my 440 lost oil pressure after an oil change and had to be towed home. At the advise of people on this forum I have removed the distributor and inserted a 5/16" tool to operate the oil pump. I am turning the shaft counter clockwise and feeling some resistance. I have the valve covers off and I can hear the oil gurgling and hissing coming from what sounds like under the intake manifold. Watching the oil gauge it doesn't appear to move or maybe just slightly.
Has anyone done this that can tell me if the gurgling and hissing is a normal sound?
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069822
09/05/11 06:22 PM
09/05/11 06:22 PM
Kirkland, Washington
Pacnorthcuda Offline
Sounds to me like there is air in the pick-up tube and the pump is struggling to fill it with oil.
Did you pre-lube the new oild filter when you did the change?
You might want to pull the filter and see if its filling.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069823
09/05/11 06:23 PM
09/05/11 06:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes that's normal...you sure the gauge is working?
Re: Need help trying to prime the oil system. [Re: Challenger 1] #1069824
09/05/11 06:26 PM
09/05/11 06:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Is the key on? the gauge is electrical, it doesn't work without power... Could be plenty of other things but gotta start with the ez stuff..
Re: Need help trying to prime the oil system. [Re: 1_WILD_RT] #1069825
09/05/11 06:32 PM
09/05/11 06:32 PM
VOABIRD Offline OP
VOABIRD  Offline OP
Thanks, yes the key is on and the gauge appears to and has worked fine. I did ground the sender wire and it pegged the gauge.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069826
09/05/11 06:36 PM
09/05/11 06:36 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Put a mech gauge on it .... THEN check it with a priming rod.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069827
09/05/11 06:38 PM
09/05/11 06:38 PM
You have an average to fair amt of drag on the drill right? W the valve covers off turn the timing marks 2 TDC #6 & (re) prime & see if the pass valve train is oiling then turn the crank 450 deg (1&1/4 turns) (rotor at #8) & prime & see if dr side oils.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069828
09/05/11 06:38 PM
09/05/11 06:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Gurgling noise could be normal or could indicate an internal leak.... What was going on with the car prior to loosing oil pressure?
Are you turning the oil drive with a drill or a speed wrench? Speed wrench won't create much pressure... Drill you should be able to get good movement out of the gauge...
Re: Need help trying to prime the oil system. [Re: dOc …] #1069829
09/05/11 06:40 PM
09/05/11 06:40 PM
You state "I have the valve covers off"---I assume there is no oil reaching the heads--you might try rotating the crank a quarter turn each side of top dead center and spinning the pump again...
Re: Need help trying to prime the oil system. [Re: 1_WILD_RT] #1069830
09/05/11 06:47 PM
09/05/11 06:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually the pump should drag the drill down pretty good.If you are using anything less than a decent 1/2 inch drill it probally wont turn if oiling properly.When I prime my 440 it darn near twists my old 1/2 inch drill from my hands.My kids 62 413 does the same.Rocky
Chrysler Firepower
Re: Need help trying to prime the oil system. [Re: Pacnorthcuda] #1069831
09/05/11 06:47 PM
09/05/11 06:47 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Very little resistance? Check all of your rocker arms to make sure you didn't spit a lifter out. There are only so many things that cause a sudden loss of oil pressure while running.
1) twisted tang on intermediate shaft (isn't that)
2) oil filter rupture (isn't that)
3) cracked pickup tube (probably not, I've seen two of these fail in my entire life)
4) pushrod/rocker failure and loss of lifter (???)
Re: Need help trying to prime the oil system. [Re: 6PakBee] #1069832
09/05/11 06:52 PM
09/05/11 06:52 PM
VOABIRD Offline OP
VOABIRD  Offline OP
The lifters and push rods appear to be OK, is there something specific I should really be looking at? Since trying to prime the oil system I have noticed the lifters seem to have pumped back up. I am using a cordless drill maybe I will use a 1/2" corded drill and see what happens.
Re: Need help trying to prime the oil system. [Re: therocks] #1069833
09/05/11 07:19 PM
09/05/11 07:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Oh I never said it was gonna spin it easily, it takes a good drill & you need to be holding it solidly or it will rip it outta your hands.. But if your braced & ready you can develop good pressure...
Re: Need help trying to prime the oil system. [Re: 6PakBee] #1069834
09/05/11 07:24 PM
09/05/11 07:24 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
5. Collapsed oil filter.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need help trying to prime the oil system. [Re: 1_WILD_RT] #1069835
09/05/11 07:25 PM
09/05/11 07:25 PM
VOABIRD Offline OP
VOABIRD  Offline OP
My engine has always run perfect, I decided to change the oil and did not fill the filter. I had driven the car about 4 miles when I noticed there was no oil pressure. When I checked the filter it didn't have much oil in it. The engine was full of oil.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069836
09/05/11 07:34 PM
09/05/11 07:34 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
....to a 1/2 corded drill.
Re: Need help trying to prime the oil system. [Re: VOABIRD] #1069837
09/05/11 09:34 PM
09/05/11 09:34 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
When we rebuilt my dads 383 several years ago the first oil change saw no oil, it primed after several tries, and then the second oil change the same thing - this time it never primed...
It was the Mopar Oil pump - the dealer we got it from ( mopar performance ) took it back after we showed them excessive clearance in the pump to cover.
We got another pump and never had another issue.
Re: Need help trying to prime the oil system. Update [Re: DJVCuda] #1069838
09/06/11 01:57 PM
09/06/11 01:57 PM
VOABIRD Offline OP
VOABIRD  Offline OP
I used a 1/2" reversible drill and I still don't feel much resistance in the oil pump. I pulled the oil pump off and it looks good, checked the relief valve and it is smooth and free. I will put everything back together and let you know what happens. I'm not very hopeful.
Re: Need help trying to prime the oil system. Update [Re: VOABIRD] #1069839
09/06/11 02:06 PM
09/06/11 02:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you pack the pump with vaseline before reinstalling it. That helps prime the pump.
Re: Need help trying to prime the oil system. Update [Re: VOABIRD] #1069840
09/06/11 02:08 PM
09/06/11 02:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What oil filter do you have on it ? Put some grease inside the pump to help with initial prime.
