Wiring hacked!Need help #1069544
09/05/11 08:45 AM
09/05/11 08:45 AM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
Ok car is a 70 challenger.Wiring is a little rough to say the least.Not weather checked and rotted at all but just some shade tree issues.Some of which i created.
First off,
I eliminated the nuetral saftey switch wiring.Why?It was junk from the trans to the rotten terminals in the bulkhead,Ok now it wont start with the key. I dont remember which holes were in the far left bulk connecter was the nuetral saftey wiring,do i need to make a jumper to each hole in the bulkhead?Anybody tell me which holes?.It wa on the far left bulk connecter.
Ok one more.I have a black ECU and a MSD 6AL box mounted under dash.There is a black with yellow chaser wire in the factory ECU plug but it goes outside and has a eyelet terminal someone has crimped on and i dont know where that goes.
Basically whatis the black yellow chaser wire for and where does it go.
Thanks so much for any help.My car has been down since april and will be firing it today.
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Wiring hacked!Need help [Re: 451 D*O*D*G*E] #1069545
09/05/11 09:25 AM
09/05/11 09:25 AM
Clarkston, MI
wldgtx Offline
wldgtx  Offline
Clarkston, MI
I cannot provide any help what so ever.
Except to tell you that if you are trying to chase a wire and where it goes.. I would look online for the wiring schematic for your car?
I had to re-wire my GTX by hand without anything and without the schematic it would have been next to impossible.
Re: Wiring hacked!Need help [Re: wldgtx] #1069546
09/05/11 09:43 AM
09/05/11 09:43 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same here - sorry but here's the diagrams - http://www.mymopar.com/index.php?pid=24
Re: Wiring hacked!Need help [Re: 451 D*O*D*G*E] #1069547
09/05/11 10:14 AM
09/05/11 10:14 AM
the house on the left.
cogen80 Offline
cogen80  Offline
negative side of the coil.
can't you just ground the terminal on the starter relay where the safety switch used to go?
Re: Wiring hacked!Need help [Re: cogen80] #1069548
09/05/11 01:30 PM
09/05/11 01:30 PM
Hr up from KCK
Hr up from KCK
Thanks so much for the diagrams.But my car would have been points so this black ECU is from who know.And the black with yellow tracer comes off the plug and goes into the engine compartment to nowhere??
Yes the grounding of the nuetral came to me hadndt done it since high school so i forgot.I hooked a jumper up to see if that would work and it did.
ANy help on the black yella tracer from the ecu help would be great but understand its not possible without being here.
THanks guys.Fire up in a few minutes.
Re: Wiring hacked!Need help [Re: 451 D*O*D*G*E] #1069549
09/05/11 02:17 PM
09/05/11 02:17 PM
Which setup r u going w, points/ecu or msd. On the black w yellow tracer yes it'll need 2 go to the coil neg if your running the ECU
