what valtrian would you recomend at 8500
#1069533
09/05/11 08:14 AM
09/05/11 08:14 AM
Posts: 317 Indiana
79_W200
Indiana
this is in a pulling truck so a normal pass is about 20 secounds of full rpm. would you go with Ti valves? Will the T&D single shaft rockers hold? cam is .715 roller using .120 wall p-tubes and planning to run comp 947 springs(comps recomended). thanks for any input
1979 W200 470
Re: what valtrian would you recomend at 8500
[Re: bumps440]
#1069536
09/05/11 02:03 PM
09/05/11 02:03 PM
Posts: 317 Indiana
79_W200
Indiana
Sorry about that they are indy -1 cast iron for rules 2.25 int valve
1979 W200 470
[Re: 79_W200]
#1069537
09/05/11 03:45 PM
09/05/11 03:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would go with the TD or Jesel rockers only plus I would go with Pac springs... I like the Ti valves but they are about $100 each
[Re: 79_W200]
#1069538
09/05/11 04:56 PM
09/05/11 04:56 PM
Posts: 1,170 Westbury, NY
bumps440
super gas
super gas
Westbury, NY
Check out the Ferrea catolog online. I am using a set of their 2.25 hollow stem valves for my CNC Victors that I am having done. I wlll be seeing around 8000 in this combination.
[Re: MR_P_BODY]
#1069539
09/05/11 07:15 PM
09/05/11 07:15 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You dont have much choice... Like Mr-P said T&D or Jesel. Might as well cross T&D's you speak of off that list. The wont work with those springs which are 1.645-1.65 or so.... You cant even run 1.625 springs with those rockers without clearancing the rocker arms. I ran this very setup. and turned it 8K a few times. Jesel 1.7 rockers Manton PushRods .120 wall Pac springs and Titanium retainers. I ran this setup for 3+ seasons, never had the first single issue. Spray bat valve covers I made my self. Use ball end/ball end pushrods, have the cup on the adjuster side.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: bumps440]
#1069540
09/05/11 08:17 PM
09/05/11 08:17 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
8500 rpms for over 20 seconds... imo dont use hollow valves. stick with some tried and true solids..
[Re: mcat4321]
#1069541
09/05/11 08:39 PM
09/05/11 08:39 PM
At that RPM you really need Titanium valves--no question--you also need the best springs you can find--I would call PSI or the guys at CV Products-at that RPM it is time for Del West or similar quality Titanium retainers not the plain ole Comp junk--I would go Jesel all the way--Manton pushrods--spring location and control is a must and to be very honest you are past the threshold where a belt drive timing set will REALLY payoff--it reduces harmonics that destroy normal valvetrains and at that constant kind of RPM I would make sure I had the belt drive first even if you did nothing else. Get the Jesel NOT the cheapie Aussie copy! Time for a REAL damper as well--ATI is tops if you check hub/crank fit before you install-- I have done two winning pulling engines that are like you are running--had several trys at both builds and learned plenty--it ain't drag racing for sure! And remember--HP is not how pulling is won--it is all that science about wheel speed / drawbar etc Good Luck!
[Re: ]
#1069542
09/06/11 09:31 AM
09/06/11 09:31 AM
Posts: 317 Indiana
79_W200
Indiana
thanks for the input thats the way i was leaning. Just wanted some opinion before i dropped the cash for all the jesel setup. What is a ball park cost on having the heads machined for jesel rockers
1979 W200 470
