Trouble keeping fuel to carb #1068818
09/04/11 08:59 AM
09/04/11 08:59 AM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
I think I know the answer to this, but I will ask anyway.
So I have my 440 in my GTX and wanted to get the motor running, so I ran the fuel line from the tank to the fuel pump, then pump to the carb. The return line was left open (this was a temporary thing).
I am unable to keep fuel pressure to the carb and I am thinking that this is due to the return line left open. Does this make sense or am I way off?
Also, does everyone run with the fuel vapor separator or have you removed it?
Re: Trouble keeping fuel to carb [Re: wldgtx] #1068819
09/04/11 02:41 PM
09/04/11 02:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What do you mean return line left open? Isn't it pouring fuel if you don't have it hooked up? You can run it with the vapor seperator disabled by putting a hose clamp on the rubber part of the vapor return hose.
Re: Trouble keeping fuel to carb [Re: DaytonaTurbo] #1068820
09/04/11 10:05 PM
09/04/11 10:05 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
I had the fuel feed line connected to the pump, and the outlet connected to the carb... I did not have anything connected to the return line and did not have the fuel vapor separator connected.
