What do you mean return line left open? Isn't it pouring fuel if you don't have it hooked up? You can run it with the vapor seperator disabled by putting a hose clamp on the rubber part of the vapor return hose.
I had the fuel feed line connected to the pump, and the outlet connected to the carb... I did not have anything connected to the return line and did not have the fuel vapor separator connected.
