i am seeing all of these white foam gaskets between the master cylinder and ..well mostly bendix boosters
THIS IS ABSOLUTELY WRONG.you cannot set pushrod depth correctly when one of the clearances..squishes...my old timers say when the master started leaking..they would throw a gasket on..force the leaking fluid into the booster, hiding the problem and sell the junk... and i have been ask to do that ..never ever ever
