as fluid heats up there is always expansion..and things already lacking propper clearance get multiplied
one of the main reasons brakes release slowly ... the micro size return ports on the original factory master cylinder pistons are clogged.......easily determined with a simple master cylinder bench bleed...the rear piston will be slow to return..and this 10 min test..removes the rest of the system from liability now
thats wonderful
