Page 1 of 19 1 2 3 18 19
After 8 years my 71 340 Duster is off for paint & body! #1067925
09/02/11 11:10 PM
09/02/11 11:10 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Well I finally spent some time on my own car this week, bought a new rotisserie and mounted up my long term 71 340 Duster project for paint and body! I have it pretty well stripped of everything, just a few more trinkets remain. I have been photographing any interesting details along the way and will continue to do so throughout the duration of the restoration, tomarrow I will be steam cleaning the chassis to clean up the grease oil and to remove the small amount of under coating it has. It is scheduled to be painted next spring and back to me for assembly, that gives me plenty to work on this winter.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067926
09/02/11 11:10 PM
09/02/11 11:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1 of 5
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067927
09/02/11 11:11 PM
09/02/11 11:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2 of 5
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067928
09/02/11 11:12 PM
09/02/11 11:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3 of 5
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067929
09/02/11 11:12 PM
09/02/11 11:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
4 of 5
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067930
09/02/11 11:13 PM
09/02/11 11:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
5 of 5
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067931
09/02/11 11:38 PM
09/02/11 11:38 PM
MO
cdp Offline
cdp  Offline
MO
What them torque boxes on there for?
Your not going to paint it back that bug-luring yellow are you?
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: cdp] #1067932
09/03/11 12:13 AM
09/03/11 12:13 AM
New State
kidmopar Offline
kidmopar  Offline
New State
Looks GREAT Scott! Lots & lots to do! Keep us up to speed as the project moves along.........
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: kidmopar] #1067933
09/03/11 12:18 AM
09/03/11 12:18 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
needs to be a Projects thread bro.... will be watching......
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: UCUDANT] #1067934
09/03/11 12:37 AM
09/03/11 12:37 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Good to see another a-body being done the right way.
I have only seen one car in that color so far (a 71 340 demon), and I thought it looked great.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067935
09/03/11 10:56 AM
09/03/11 10:56 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Good Luck. I'm an e-body guy, but I always loved those Dusters.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: cudabitten] #1067936
09/03/11 06:25 PM
09/03/11 06:25 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
Thanks for sharing the pics. My GY3 Duster 340 ( the one I tried to sell you )is also finally getting to the paint shop. It has been on a rotisserie for 2 years and I almost gave up on getting someone to paint it. Good luck!
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: fc7freak] #1067937
09/03/11 06:52 PM
09/03/11 06:52 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Congrats!! I'll be watching your progress for sure!! Glad to hear its going to be painted soon.
Im curious about how you have you rotisserie attached, thats different that most I've seen. Can you post a couple of close up pics of the brackets attached to the body? Mine will be going on the rotisserie this week.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: NV69B7RR] #1067938
09/03/11 08:21 PM
09/03/11 08:21 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Looks like fun
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: NV69B7RR] #1067939
09/03/11 08:30 PM
09/03/11 08:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The fronts are made from a reciever hitch female with two anchor point nuts welded onto them for the set bolts. A piece of angle iron welded to it at a 90 gives it a flat to bolt against the frame. The attachment method uses the factory bumper bolts and holes. As you can see the rotisserie stubs slide right into it and you can slide a bolt through the holes that are already there to have a safely measure.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067940
09/03/11 08:41 PM
09/03/11 08:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The rears are not the typical bolt flat against the bumper bracket sheet metal style, they were made so the rotisserie stubs could go inward toward the center of the car allowing for a shorter overall rotisserie rig. The same reciever hitch tubing with set bolt nuts welded on and angle iron welded at a 90 as was used on the front brackets but wider angle iron to allow enough room to space the bolt holes appropriately.
The mounts utilize the existing frame through holes at the rear of the frame (a large dia. nut and bolt) and the single/smaller threaded in bolt that holds the rear muffler hanger mount. An approx 2 x 4" piece of flat steel plate is used as a "washer" on the opposite side of the frame to spread the load and not pinch the frame material. The big 90 black clamp shown was added just as a safety to keep things in place as weight shifted, it's not really needed. Setup like this the car is rock solid and turns all the way around with one hand.
Be careful mounting your car so that it's centered and at the right hieght to be balanced when turning, also be sure all doors, hood, truck, etc. are wired closed. Get a buddy to help you and GO SLOWLY, you don't want a disaster and you only get one shot!
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067941
09/03/11 08:43 PM
09/03/11 08:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
90 clamp mentioned
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067942
09/03/11 08:43 PM
09/03/11 08:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
First bath, next up is the steam cleaner
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067943
09/03/11 09:03 PM
09/03/11 09:03 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Thanks Scott! I really like how your rear brackets attach, looks like a much better/ stronger set up.
Are you going to get this thread moved to the projects/ survivor section and update your resto progress????
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1067944
09/03/11 09:04 PM
09/03/11 09:04 PM
MO
cdp Offline
cdp  Offline
MO
Cant wait to see how the steam cleaner works out. Keep us posted. Are you renting a steam cleaner or are you having a company come by and do it?
