Re: Leaf springs and sliders
[Re: blue_stocker]
#1067619
09/02/11 05:45 PM
09/02/11 05:45 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Jim Guy put sliders on his 64' car. I amsure he would fill you in on if/how they helped.
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: StrokerAspen]
#1067621
09/02/11 05:54 PM
09/02/11 05:54 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine have been on my car for 3 years with no problems, it lowered about 1 3/4,we put them in the frame rails after notching them out.Mine sees a lot of street duty as well and has low 1.42 60 fts.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: mopar400]
#1067623
09/02/11 07:09 PM
09/02/11 07:09 PM
Posts: 1,451 central ohio
nss guy
central ohio
Bob's ProFab put them on with the CalTrac's Not sure of the ride height difference but they work! I've been 1.39 60ft 'detuned'
[Re: StrokerAspen]
#1067625
09/02/11 10:13 PM
09/02/11 10:13 PM
Posts: 515 Temperance, MI
68 HEMI GTS
Temperance, MI
i have a set of afco's on my car. i did them the same time as the caltracs so i don't really have a before or after. they seem to work good, i have a ton of street miles on mine also, are they any better. im still not really convinced either way.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#1067626
09/02/11 10:54 PM
09/02/11 10:54 PM
Posts: 1,377 Ohio
Todd
Ohio
Put a set on from speedway motors to correct a clearance issue. Lowered the car about an inch. 13 runs on it since The car was completed and so far so good.
[Re: blue_stocker]
#1067628
09/03/11 06:24 AM
09/03/11 06:24 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Wish I had known about the cheaper Speedway unit.
I posted pics of sliders I installed and was chastised because I mounted them level. They would work a little better if they were angled with the arc of the spring. I used them as it was easy to fit them against the frame. I notched the front frame to get the springs as high as I could sense we are no longer planning on hauling wood. LOL
Have not ran the truck yet. Owner has really slowed down on me. If you know what I mean.
Leon
[Re: VernMotor]
#1067631
09/03/11 10:25 AM
09/03/11 10:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So when they are install at ride height and car is on the ground with full weight on them. Are they install center or toward the back ? How long are they ? What is the full travel of them ? And why would they be better then shackles that are mounted right ?
They ride on a bearing which is free VS riding in rubber which tends to bind then snap free... its just smoother
[Re: MR_P_BODY]
#1067632
09/03/11 10:28 AM
09/03/11 10:28 AM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
Not to mention it helps eliminate rear end sway.
[Re: MIKES_DUSTER]
#1067635
09/04/11 12:04 AM
09/04/11 12:04 AM
Posts: 1,377 Ohio
Todd
Ohio
[Re: VernMotor]
#1067637
09/04/11 10:59 AM
09/04/11 10:59 AM
Posts: 344 Burlington, Ontario Canada
Dave_S
FYI I called Calvert and asked them about sliders. In their opinion the did not improve your suspension over a properly set up shackle. By "properly set up" they meant no binding and the correct working angle. This was one month ago.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
