318 Spark Problem #1067122
09/01/11 07:50 PM
09/01/11 07:50 PM
Rome, PA
Ryan_340 Offline OP
Ryan_340  Offline OP
Rome, PA
The 318 in my '73 Power Wagon only has a sudden instance of spark coming out of the coil when you turn it over. After that it just rolls over and over with no spark.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: 318 Spark Problem [Re: Ryan_340] #1067123
09/01/11 08:14 PM
09/01/11 08:14 PM
scratchnfotraction Offline
points or elect dist?
check your BR.
check your fusable links.
Re: 318 Spark Problem [Re: Ryan_340] #1067124
09/01/11 08:53 PM
09/01/11 08:53 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
bad ground or bad ECM. you will also get spark when you turn off the key ?
Re: 318 Spark Problem [Re: scratchnfotraction] #1067125
09/02/11 01:32 AM
09/02/11 01:32 AM
Likely ballast or ECU. take off the yellow "sol" wire from the starter relay to disable the starter & have a helper hold the key to "start" & w a VOM/test light you need fire at (1) the coil positive pri terminal and (2) 2 pins (if 5 pin ECU/1 pin if 4 pin ECU) at the pentastar ECU connector. Let key off to "run" & need fire the same on the coil but only 1 pin of the ECU, the "point" of the pentastar connector. Pull/ check/clean the bulkhead connectors EDIT less likely but check the pickup gap/ohm it if u can
Re: 318 Spark Problem [Re: RapidRobert] #1067126
09/02/11 10:45 AM
09/02/11 10:45 AM
Rome, PA
Ryan_340 Offline OP
Ryan_340  Offline OP
Rome, PA
I have also noticed that the ignition wires coming out of the column are very hot with the key on.
