Flaming river power to manual conversion... #1066845
09/01/11 11:59 AM
09/01/11 11:59 AM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Hey all,
I would like to do this conversion.
Does anyone have any pics of the unit installed with box and adapter?
Just curious what it will look like.
Btw, all I need it the box and adapter correct? existing pitman is okay?
Does anyone have any other suggestions to make this swap without using flaming river? I cant seem to find manual boxes anywhere. Plus, Ive heard they can be brutal with the ratio.
Any help is appreciated. Thanks
Re: Flaming river power to manual conversion... [Re: newbee69] #1066846
09/01/11 12:19 PM
09/01/11 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
depends on your current steering box , if it is original 69 then it has the small output sector , the flaming river is more than likely the large. If so you need to purchase a new pitman arm , pretty sure application to ask for is for a 73 B body , I put a large sector PS box in a 68 and pretty sure that is what I ordered.
Re: Flaming river power to manual conversion... [Re: JohnRR] #1066847
09/01/11 03:36 PM
09/01/11 03:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can see my adapter here. Its gray and the shaft is black. Ron
Re: Flaming river power to manual conversion... [Re: newbee69] #1066848
09/01/11 03:56 PM
09/01/11 03:56 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
All you need is the existing top half of the shaft and a box with a manual lower half shaft stick the two together and you are done.
No adapter required.
