Re: grill paint removal
[Re: rowin4]
#1066679
08/31/11 11:57 PM
08/31/11 11:57 PM
Posts: 654 MN
astrobuf
MN
I've used easy-off oven cleaner with success on plastic models. Shold work as well on your grille.
Spray it on, bag it in a large trash bag, wait 30 minutes and wash it off.
Astrobuf
So, are you really a Rocket Scientist?
[Re: Bigfury]
#1066681
09/02/11 09:01 AM
09/02/11 09:01 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
outstanding! I'll have to give the easy-off a shot. I'm not sure about bagging it though, doesn't that stuff give off hydrogen gas? bagging it gives you a giant hydrogen balloon. can anyone say "Hindenburg?"
or is that only when you use it on aluminum to remove anodizing, and the cleaner reacts with the aluminum?
anyway...that stock paint is tough stuff! I had a spot coming off on my grille, tried to sand it smooth so I could spray bomb it to make it look better while I had the car still on the road...and it wouldn't sand! instead, it would slowly flake off instead of sanding smooth. instead of getting the flat smooth transition that you wont see once painted...it remained a hard edge that even primer wouldn't fill.
I gave up and just painted it as it was, since the rest of the car was at the time, in rough shape.
**Photobucket sucks**
[Re: 70Cuda383]
#1066682
09/02/11 06:29 PM
09/02/11 06:29 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
That's the problem I have. Paint seems real hard, doesn't sand well a flakes/chips off. Will try the oven cleaner.
[Re: rowin4]
#1066683
09/02/11 06:50 PM
09/02/11 06:50 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
good luck with getting the original paint off the grill with easy off, I tried it with little success. works great on any other spray bombed stuff
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
