Dual Plane Manifold differences. #1066493
08/31/11 01:26 PM
08/31/11 01:26 PM
Arizona
68CoronetRT Offline OP
Arizona
I am trying to understand why some intakes have a solid bridge dividing the manifold and others have a "cut away" bridge and yet both are called Dual Plane Manifolds.
Wouldn't the cut away bridge actually defeat the Dual Plane effect? Isn't it more of a Hybrid?
Sorry if this is an elementary question for y'all but I don't get it.
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066494
08/31/11 01:41 PM
08/31/11 01:41 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
This is a very old Mopar trick that goes back to the Edelbrock CH4B. I believe the purpose of the notch was to equalize the A/F mixture to each of the 8 cylinders.
Re: Dual Plane Manifold differences. [Re: Kudakidd] #1066495
08/31/11 02:38 PM
08/31/11 02:38 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
may extend the rpmrange on plenumlimited manifolddesigns thats how i have been looking at it atleast.
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066496
08/31/11 02:46 PM
08/31/11 02:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The divider notch is for idle quality, and it will be slightly larger for larger engines, etc.
If you open the divider window size (by cutting the divider height down, partially or all the way to the floor level of the upper plenum) top end is improved (by sharing the plenums), but off-idle response and low RPM power will be down. The effects are proportionate to the old vs. new divider window X-area.
Removed completely is inferior to a good single plane manifold since the largest window area is obviously much smaller than the plenum X-section.
Boffin Emeritus
Re: Dual Plane Manifold differences. [Re: Kudakidd] #1066497
08/31/11 03:02 PM
08/31/11 03:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don't forget the then available Holley 3 bbl carb ...
Re: Dual Plane Manifold differences. [Re: polyspheric] #1066498
08/31/11 06:03 PM
08/31/11 06:03 PM
Arizona
Arizona
Thanks for the replies and taking the time to help me try to get my head around this.
I thought I read that the dual plane intakes provided a better idle and low end response?
Also, is the "true" dual plane set up not really desirable then?
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066499
08/31/11 07:01 PM
08/31/11 07:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The dual-plane is essentially a cross between a single plane and a tunnelram - giving you some of the benefits of each but not the full benefit of either.
Those funky intakes on late model cars are getting the best of both worlds by using a vaccuum control to alternate between the short runners and long runners based on load, rpm, etc..
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066500
08/31/11 08:37 PM
08/31/11 08:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066501
08/31/11 08:48 PM
08/31/11 08:48 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I cannot speak to all manifolds over time, or even of recent design, but years ago, most aftermarket dual plane manifolds had a notch at the rear butterflies, which I believe was to accommodate the Holly 3 bbl carb.
On my 508, with considerable dyno testing, I found measurable and repeatable power improvements in playing with the divider on my 2D.
Re: Dual Plane Manifold differences. [Re: JohnRR] #1066502
08/31/11 10:25 PM
08/31/11 10:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Ding!!! we have a winner
John I thought I was the only one that has set a three barrel carb on an old CH4B to see why they put the notch in there
Gus
64 Plymouth Savoy
Dana 60
Re: Dual Plane Manifold differences. [Re: polyspheric] #1066503
09/01/11 11:16 AM
09/01/11 11:16 AM
Arizona
Arizona
Polyspheric,
Thanks for the article link.
BSB67,
When you say "playing with the divider" were you referring to milling a slot into it or closing it up?
Re: Dual Plane Manifold differences. [Re: 68CoronetRT] #1066504
09/01/11 10:05 PM
09/01/11 10:05 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Opening it up. There was no measurable loss of power from 3000 to 4000 rpm, and started picking up from there.
Re: Dual Plane Manifold differences. [Re: JohnRR] #1066505
09/01/11 10:09 PM
09/01/11 10:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ooops. Missed that you had already posted this.
Re: Dual Plane Manifold differences. [Re: BSB67] #1066506
09/01/11 10:15 PM
09/01/11 10:15 PM
Arizona
Arizona
That seems to be what I am reading. The gains on the cut away divider are in the higher RPM range.
Well I need to study that article some more. Right now I am planning to stay with a full bridge dual plane and 1" 4 hole phenolic spacer to maintain separation.
Street car so low end to 5500 should be mostly what it will see - unless I miss a gear. LOL Then the rev limiter will/should kick in.
